Civil 3D Forum
Best way to model a control weir in SWMM
1 REPLY 1
568 Views, 1 Reply
Hi all,
I am trying to model the following within SWMM.
We have an existin 8" sanitary sewer and would like to add a control weir (vertical sliding gate) to the upstream face of a manhole.  The idea is to open the sliding gate to a controled depth basically to regulate downstream flow?
The only way I can see to closely model this is to make the downstream pipe the "equivelant area" to the required flow area?
Thoughts?
Bill
1 REPLY 1
Matt.Anderson
In Autodesk Storm and Sanitary, you can add either a Weir or Orifice to represent your Gate.
I might assume that an orifice is more appropriate is the gate is sliding up to control the flow.
<Your question was about SWMM, and Autodesk Storm and Sanitary is build with SWMM...>
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Rail Community
