Civil 3D Forum
Average depth attained = 0
3 REPLIES 3
NoWandering
308 Views, 3 Replies
I just learned to use SSA. After running the model, the average depth attained is only 0.02-0.07 ft in the Node Depth Summary. What is the possible reason? Many thanks.
3 REPLIES 3
jmiller0621
in reply to: NoWandering
Sorry.  Can't answer the question without more information or a file.
Matt.Anderson
The longer you run the simulation when the depth at your node is zero, your average will decrease.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
NoWandering
in reply to: Matt.Anderson
Matt, you are right.
I figured it out before you replied this. Originally I used 30 days. After changed to 1 day, the average depth is reasonable.
Rail Community
