I don't know if this helps everything, but I modeled the storm sewer in SSA and then exported it to a .stm file.
I then imported the .stm file through Civ3d. Also found that I could then import same .stm file through the Hydraflow extension to create custom reports in that interface a bit easier.
If you have Excel, SSA can export the design and analysis to Excel for report creation.
it sure can, but HydraFlow has the DOT templates already set up so you don't have to monkey with the format.
This would be a great addition to SSA in the next round.
I would like to see all the report formats of Hydraflow (DOT, FL-DOT) plus add the formats requested by MSD in Louisville, KY as well.
Can you point me to the resource to find the format for the MSD in Louisville?
matt dot anderson at autodesk dot com
Chart example is found at http://www.msdlouky.org/insidemsd/AutoCAD/PDFs/EXH4-11_CompositeDrainage-Layout1.pdf
The storm structure chart consists of
STRUCTURE | Catchbasin | Max | ||
NUMBER | Invert | (Rim) | ||
Elevation | Elevation | PIPE | ||
TYPE | (ft) | (ft) | ||
The Pipe Chart consists of:
Pipe | From (Inlet) | To (Outlet) | Contributing | Total Drainage | Length | Average | Pipe | Pipe | Peak | Peak | Max | Max | Design Flow |
Number | Upstream Str. | Downstream Str. | Drainage Area | Area (Ac) | Slope | Diameter | Material | Flow | Flow | Velocity | Velocity | Capacity | |
Acres | ft/sec | ft/sec | cfs | ||||||||||
10 yr 1 hr | 100 yr 1 hr | 10 yr 1 hr | 100 yr 1 hr |
iwa ant to ask about storm ans sanitary analysis i
i can install i on Civil 3d 2011 UK version or no i wait the answer please
I don't see Nordic & Baltic installation file in my subscription center. The only available are US ENGLISH and UK/IRELAND ENGLISH
Can someone please help me to include the surface water lever at the outfall.
When I create the profile, it doesn't show the surface(maximum) water lever at the orifice location.
