Civil 3D Forum
Autodesk Storm and Sanitary Analysis (former StormNET) is now available!
68 REPLIES 68
Message 1 of 69
18042 Views, 68 Replies
Civil 3D and Map 3D subscription customers in North America can now download
Autodesk Storm and Sanitary Analysis Stand-Alone.
Looking forward to using this group to talk about the product and your
projects!
head over to www.autodesk.com/subscription to download the extension!
If you aren't sure if you are on subscription, ask your CAD manager or
Autodesk reseller.
The Autodesk® Storm and Sanitary Analysis Stand-Alone 2011 Extension is a
comprehensive, hydrodynamic hydrology and hydraulic analysis application for
planning and designing urban drainage systems, storm sewers including
highway drainage systems, and sanitary sewers.
With this extension, engineers and planners using AutoCAD® Civil 3D® and/or
AutoCAD® Map 3D software can analyze both simple and complex networks
including:
? Inlets and catch basins
? Detention ponds and outlet structures
? Interconnected ponds
? Flow dividers, standpipes, weirs, and orifices
? Pumps and lift stations
? Manholes and junctions
? Rivers, streams, and ditches
? Culverts and bridges
Some of the key features and benefits of the Autodesk Storm and Sanitary
Analysis Stand-Alone Extension are:
? Bi-directional exchange of data with AutoCAD Map 3D and AutoCAD Civil 3D
? No limitation on the number of pipes or elements you can include in your
model
? Widely-accepted SWMM analysis engine
? Broad range of hydrologic methods
? Stormwater BMPs
? Detention pond design
? Stormwater quality modeling
? Customizable report generation for regulatory review
? GIS interoperability
? Work in either US or Metric (SI) units
I wrote a blog post about the release
here:http://bimontherocks.typepad.com/my_weblog/2010/04/autodesk-storm-and-sanitarty-analysis-former-stormnet-is-now-available.html
and Matt Anderson wrote one
here:http://civil3dpedia.com/2010/04/30/autodesk-storm-and-sanitary-analysis-stand-alone-2011-is-live/
Dana Probert, P.E.
Technical Marketing Manager, Civil Engineering
http://www.facebook.com/autocadcivil3d
68 REPLIES 68
Message 61 of 69
in reply to: subpartner
I don't know if this helps everything, but I modeled the storm sewer in SSA and then exported it to a .stm file.
I then imported the .stm file through Civ3d.  Also found that I could then import same .stm file through the Hydraflow extension to create custom reports in that interface a bit easier.
Message 62 of 69
Matt.Anderson
If you have Excel, SSA can export the design and analysis to Excel for report creation.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 63 of 69
in reply to: Matt.Anderson
it sure can, but HydraFlow has the DOT templates already set up so you don't have to monkey with the format.
This would be a great addition to SSA in the next round.
I would like to see all the report formats of Hydraflow (DOT, FL-DOT) plus add the formats requested by MSD in Louisville, KY as well.
Message 64 of 69
Matt.Anderson
Can you point me to the resource to find the format for the MSD in Louisville?
matt dot anderson at autodesk dot com
Product Manager
Autodesk (Innovyze)
Message 65 of 69
Chart example is found at http://www.msdlouky.org/insidemsd/AutoCAD/PDFs/EXH4-11_CompositeDrainage-Layout1.pdf
The storm structure chart consists of
STRUCTURE CatchbasinMax
NUMBER Invert(Rim)
  ElevationElevationPIPE
 TYPE(ft)(ft)
The Pipe Chart consists of:
PipeFrom (Inlet)To (Outlet)Contributing Total Drainage LengthAveragePipePipe PeakPeakMaxMaxDesign Flow
NumberUpstream Str.Downstream Str.Drainage AreaArea (Ac) SlopeDiameterMaterialFlowFlowVelocityVelocityCapacity
   Acres       ft/secft/seccfs
         10 yr 1 hr100 yr 1 hr10 yr 1 hr100 yr 1 hr
Message 66 of 69
iwa ant to ask about storm ans sanitary analysis i
i can install i on Civil  3d 2011 UK version or no i wait the answer please
Message 67 of 69
Fantoon
I don't see Nordic & Baltic installation file in my subscription center. The only available are US ENGLISH and UK/IRELAND ENGLISH
AutoCad 2019 & Civil3D 2019.
Lenovo P52
Intel i7 8850H @ 2.6GHz
32 GB RAM
512 GB SSD
NVIDIA Quadro P2000
Message 68 of 69
Actually I don not agree with you. I have worked with SewerGems , that is really user friendly, you can analyze and design networks (separate and combined) also can assign loads+Inflow +infiltration(flow/length) also defin a library for pipe section size and.....
But, I can't find these items at SSA-2013 !
I recentely started my job at a company, they have Civil3d+SSA2013.
I am encouraging my manager to switch to SewerGems , because of above reasons , also another issue is, I have tried to ask my questions at this website but after 4-5 months nobaody hasn't anwered to my questions.
Thanks Hamid
Message 69 of 69
Can someone please help me to include the surface water lever at the outfall.
When I create the profile, it doesn't show the surface(maximum) water lever at the orifice location.
Rail Community
