Attached is a screenshot of one of my profiles in the file. Exporting/importing to a new file was unsuccessful.
I would suggest that if you could try the following steps to overcome the problem you mentioned.
- Uninstall SSA Stand-Alone.
- Delete the Application folder (C:\Program Files\Autodesk\SSA Stand-Alone 2011 or where you installed SSA), if exists after uninstall.
- Delete the folder “%ALL_USERS%\Application Data\Autodesk\SSA Stand-Alone 2011
- Reinstall SSA Stand-Alone.
Debajit
@wsuswim147 wrote:Attached is a screenshot of one of my profiles in the file. Exporting/importing to a new file was unsuccessful.
RE: web cast of 19-Aug-10
Hello Dana,
In Western Washington engineers are reluctant to use SAA because there are three programs actively used, KCRTS, KCBW and WWHM3. KCRTS is a required program in King County it is the largest population county in Washington. This program is an old program developed in 1992. It is the King County Runoff Time Series (KCRTS), which is a variant of the Hydrologic simulation Program – FORTRAN (HSPF) model. Unfortunately one of the issues with the KCRTS program is that it uses ten year modified rain fall data in 15 minute and one hour time series.
The next program required by King County is the KCBW King County backwater analysis model for performing standard step hydraulic analyses.
The third program of high priority in Western Washington is the WWHM3 program, developed for Washington State DOT. The WWHM3 uses HSPF (Hydrological Simulation Program Fortran) as its computation engine.
Due to the steady type of rain fall in the Western Washington the HSPF continuous simulation model is preferred over single-event hydrology models because of its ability to compute and keep track of all of the individual components of the hydrologic cycle including surface runoff, interflow, groundwater, soil moisture, and evapotranspiration.
If these three programs can be addressed in SSA then you would expand your client base by several thousand engineers in this region. If you need any further information let me know and I’ll be of assistance.
I was the one who asked the question regarding the stage-storage pond question in your 19-August webcast. The question is for me to use the stage-storage pond extension then I have to go back to 2010 civil 3d version to run the extension then bring that information forward into 2011. It simply does not work in the Civil 3d version.
Bill Porter
OmegaPAR
Bill -
Can you contact me off the Discussion Group to discuss your Stage-Storage issue? first dot last at Autodesk dot com.
Typically, your best bet when you have a problem that causes you to drop back a version, it is best to open a Support Request with the steps that describe your error.
Matt Anderson, PE
We are currently in the process of evaluating SSA vs. SewerCAD. I am new to sewer modeling other than what we used to do with Eaglepoint Sanitary Sewers modeling. Can anyone provide me with reasons to choose one over the other? Can SSA do everything SewerCAD can? or the other way around? We are going to be modeling a system with around 2000 pipe segements 10-15 pump stations. Thanks in advance for any input.
Kendall -
Two questions: Do you own SewerCAD? Are you on Autodesk Subscription?
SSA provides both Storm and Sanitary modeling. If you next project is a storm sewer network, with SSA, you already have the program analysis package. With SewerCAD, you need to purchase a different program with a different interface, with different licensing, and different data requirements.
SewerCAD is more a steady state modelling solution. I assume the EaglePoint modeling is similar to steady state analysis. I think you would need SewerGEMS if you have more wet weather / combined sewers to model.
SSA is fully hydrodynamic - which is more like SewerGEMS and CivilStorm together.
Hopefully that gets you started.
I do not own SewerCAD and we are on subscription. I have allready downloaded and have just messed around with the sample files a bit.
Does steady state provide any advantages over fully hydrodynamic?
SSA is included in your Civil 3d subscription. You will be able to use Civil 3d pipe networks to layout your sewer system and import it into SSA.
Steady State is simplistic routing.
Are you designing new or analyzing existing?
I would like do both. For the project I mentioned previously we will basically be doing analysis. But following the analysis we will be designing new and verifying that the new meets current state regulations. (310 gpd/home, etc.).
It's now been 5 months since this was released in North America..... Any update as to when it will be rolled out for the rest of us?
Pete
I understand this is being released in the UK tomorrow (28.10.2010).
Pete
In addition to the US, Canada, Australia, New Zealand and South Africa, the subscription extension is now available to the following countries:
Benelux |
Belgium |
Luxembourg |
Netherlands |
Nordic & Baltic |
Denmark |
Estonia |
Faroe Islands |
Finland |
Greenland |
Iceland |
Latvia |
Lithuania |
Norway |
Svalbard and Jan Mayen Islands |
Sweden |
UK & Ireland |
Ireland |
United Kingdom |
For the rest of the world- stay tuned!
date/time : 2010-11-02, 11:53:20, 669ms computer name : BTM-LEX02 user name : sgarland <admin> registered owner : Microsoft / Microsoft operating system : Windows NT New x64 build 7600 system language : English system up time : 1 day 4 hours program up time : 5 minutes 46 seconds processors : 8x Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz physical memory : 1268/8151 MB (free/total) free disk space : (C:) 327.04 GB display mode : 1920x1080, 32 bit process id : $1454 allocated memory : 723.98 MB executable : StormSanitary.exe exec. date/time : 2010-04-19 17:00 version : 5.0.14.1189 compiled with : Delphi 7 madExcept version : 3.0i beta 2 contact name : Steve Garland contact email : sgarland@btmeng.com callstack crc : $06d6ec64, $cd56259a, $cd56259a exception number : 2 exception class : EConvertError exception message : '*' is not a valid floating point value. main thread ($1480): 0040cc8d +0019 StormSanitary.exe SysUtils ConvertErrorFmt 0041030a +002e StormSanitary.exe SysUtils StrToFloat 0054c014 +001c StormSanitary.exe StringUtils 64 +7 StringToFloat 00df60e0 +0060 StormSanitary.exe InletsForm 14542 +12 TFInlets.DisplayDataStructureValuesInControls 00df78d8 +025c StormSanitary.exe InletsForm 15479 +66 TFInlets.LoadCaltransValues 00de9c10 +0804 StormSanitary.exe InletsForm 8534 +158 TFInlets.GridClick 00deaa94 +0000 StormSanitary.exe InletsForm 8958 +0 TFInlets.GridFrameCurbGutterADVGridClick 005262c8 +0064 StormSanitary.exe Controls TControl.Click 0064a2a5 +0005 StormSanitary.exe AdvGrid 30191 +1 TAdvStringGrid.Click 00597d56 +01b2 StormSanitary.exe Grids TCustomGrid.MouseDown 0065fe8a +02a6 StormSanitary.exe AdvGrid 32517 +0 TAdvStringGrid.MouseDown 0052639e +0076 StormSanitary.exe Controls TControl.DoMouseDown 005263ea +003e StormSanitary.exe Controls TControl.WMLButtonDown 00598eed +0005 StormSanitary.exe Grids TCustomGrid.WMLButtonDown 006537aa +22ee StormSanitary.exe AdvGrid 32517 +0 TAdvStringGrid.WMLButtonDown 00526130 +0188 StormSanitary.exe Controls TControl.WndProc 005291e3 +0157 StormSanitary.exe Controls TWinControl.WndProc 00665414 +1214 StormSanitary.exe AdvGrid 32517 +0 TAdvStringGrid.WndProc 00528e60 +002c StormSanitary.exe Controls TWinControl.MainWndProc 00432db4 +0014 StormSanitary.exe Classes StdWndProc 7713810d +000a user32.dll DispatchMessageA 00547243 +0083 StormSanitary.exe Forms TApplication.ProcessMessage 0054727a +000a StormSanitary.exe Forms TApplication.HandleMessage 0054749a +0096 StormSanitary.exe Forms TApplication.Run 00f880c9 +0185 StormSanitary.exe StormNET 223 +55 initialization 773d3675 +0010 kernel32.dll BaseThreadInitThunk thread $89c: 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $1538: 759d0810 +92 KERNELBASE.dll WaitForSingleObjectEx 773d117f +3e kernel32.dll WaitForSingleObjectEx 773d1133 +0d kernel32.dll WaitForSingleObject 004cd4bd +0d StormSanitary.exe madExcept CallThreadProcSafe 004cd527 +37 StormSanitary.exe madExcept ThreadExceptFrame 773d3675 +10 kernel32.dll BaseThreadInitThunk >> created by main thread ($1480) at: 72144bc3 +00 winspool.drv thread $1028: 759d0810 +92 KERNELBASE.dll WaitForSingleObjectEx 773d117f +3e kernel32.dll WaitForSingleObjectEx 773d1133 +0d kernel32.dll WaitForSingleObject 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $b88: <priority:1> 759d0810 +92 KERNELBASE.dll WaitForSingleObjectEx 773d117f +3e kernel32.dll WaitForSingleObjectEx 773d1133 +0d kernel32.dll WaitForSingleObject 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $5d8: <priority:1> 759d0810 +92 KERNELBASE.dll WaitForSingleObjectEx 773d117f +3e kernel32.dll WaitForSingleObjectEx 773d1133 +0d kernel32.dll WaitForSingleObject 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $15a8: <priority:1> 759d0810 +92 KERNELBASE.dll WaitForSingleObjectEx 773d117f +3e kernel32.dll WaitForSingleObjectEx 773d1133 +0d kernel32.dll WaitForSingleObject 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $670: 759d095c +fa KERNELBASE.dll WaitForMultipleObjectsEx 773d1628 +89 kernel32.dll WaitForMultipleObjectsEx 773d191c +13 kernel32.dll WaitForMultipleObjects 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $1a0: 759d2c4a +5f KERNELBASE.dll SleepEx 759d351b +0a KERNELBASE.dll Sleep 004cd4bd +0d StormSanitary.exe madExcept CallThreadProcSafe 004cd527 +37 StormSanitary.exe madExcept ThreadExceptFrame 773d3675 +10 kernel32.dll BaseThreadInitThunk >> created by main thread ($1480) at: 755b642e +00 ole32.dll thread $140c: 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $e24: 773d3675 +10 kernel32.dll BaseThreadInitThunk thread $8e0: 773d3675 +10 kernel32.dll BaseThreadInitThunk modules: 00400000 StormSanitary.exe 5.0.14.1189 C:\Program Files (x86)\Autodesk\SSA Stand-Alone 2011 0d8f0000 VISIOF~1.OCX 4.0.0.2 C:\PROGRA~2\Autodesk\AWA\Support\VIDEOR~1 0f9a0000 VBAJET32.DLL 6.0.1.9431 C:\Windows\system32 0f9c0000 expsrv.dll 6.0.72.9589 C:\Windows\system32 10000000 PEGRPCS.DLL 5.0.0.22 C:\Windows\system32 55410000 acdb18.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 5d5c0000 AdImaging.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 5d7e0000 AcGe18.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 5d910000 quartz.dll 6.6.7600.16385 C:\Windows\SysWOW64 5da90000 ieframe.DLL 8.0.7600.16385 C:\Windows\system32 5f7f0000 wmvencod.dll 6.1.7600.16385 C:\Windows\SysWOW64 5f980000 wmvxencd.dll 6.1.7600.16385 C:\Windows\SysWOW64 5fa70000 WMADMOE.DLL 6.1.7600.16385 C:\Windows\SysWOW64 5fb50000 WMVCORE.DLL 12.0.7600.16385 C:\Windows\system32 62710000 ATL90.DLL 9.0.30729.4148 C:\Windows\WinSxS\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4148_none_51ca66a2bbe76806 629e0000 WMSPDMOE.DLL 6.1.7600.16385 C:\Windows\SysWOW64 62b40000 msjet40.dll 4.0.9756.0 C:\Windows\SysWOW64 62cd0000 comsvcs.dll 2001.12.8530.16385 C:\Windows\system32 63ab0000 msado15.dll 6.1.7600.16385 C:\Program Files (x86)\Common Files\System\ado 64bd0000 dsound.dll 6.1.7600.16385 C:\Windows\system32 65390000 acdb18enures.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 65400000 mfc90u.dll 9.0.30729.4148 C:\Windows\WinSxS\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4148_none_4bf5400abf9d60b7 66ff0000 cf2407.dll 1.2.0.1162 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 676f0000 AcMPolygonObj18.dbx 14.0.39.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 67730000 mswstr10.dll 4.0.9756.0 C:\Windows\SysWOW64 67910000 wmvsencd.dll 6.1.7600.16385 C:\Windows\SysWOW64 67980000 msjtes40.dll 4.0.9756.0 C:\Windows\SysWOW64 679e0000 AdIntImgServices.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 67a00000 acismobj18.dbx 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 67cd0000 bcryptprimitives.dll 6.1.7600.16385 C:\Windows\SysWOW64 67d20000 msadce.dll 6.1.7600.16385 C:\Program Files (x86)\Common Files\System\msadc 67e70000 OLEDB32R.DLL 6.1.7600.16385 C:\Program Files (x86)\Common Files\System\Ole DB 67e90000 bcrypt.dll 6.1.7600.16385 C:\Windows\system32 67eb0000 MSDART.DLL 6.1.7600.16385 C:\Windows\system32 67ed0000 oledb32.dll 6.1.7600.16385 C:\Program Files (x86)\Common Files\System\Ole DB 68e50000 mfplat.DLL 12.0.7600.16385 C:\Windows\system32 69530000 AdImagingRes.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 69570000 shdocvw.dll 6.1.7600.16385 C:\Windows\System32 69650000 AcUt.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 696f0000 atiu9pag.dll 8.14.1.6117 C:\Windows\system32 69700000 VCOMP90.DLL 9.0.30729.4148 C:\Windows\WinSxS\x86_microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.4148_none_80b7c8a91e9dd16a 69710000 Ac1st18.dll 18.1.49.0 C:\Program Files (x86)\Autodesk\AWA\Support\RealDWG2011 69730000 devenum.dll 6.6.7600.16385 C:\Windows\SysWOW64 697a0000 msjetoledb40.dll 4.0.9756.0 C:\Windows\SysWOW64 69860000 msadp32.acm 6.1.7600.16385 C:\Windows\system32 69880000 msgsm32.acm 6.1.7600.16385 C:\Windows\system32 698d0000 msg711.acm 6.1.7600.16385 C:\Windows\system32 698e0000 imaadp32.acm 6.1.7600.16385 C:\Windows\system32 69af0000 l3codeca.acm 1.9.0.401 C:\Windows\SysWOW64 69b10000 WMASF.DLL 12.0.7600.16385 C:\Windows\system32 69b50000 msadrh15.dll 6.1.7600.16385 C:\Program Files (x86)\Common Files\System\ado 69db0000 ieproxy.dll 8.0.7600.16385 C:\Program Files (x86)\Internet Explorer 69fe0000 msjter40.dll 4.0.9756.0 C:\Windows\SysWOW64 6a000000 msdmo.dll 6.6.7600.16385 C:\Windows\system32 6a010000 msadcer.dll 6.1.7600.16385 C:\Program Files (x86)\Common Files\System\msadc 6b2f0000 EhStorShell.dll 6.1.7600.16385 C:\Windows\system32 6bc00000 ATL.DLL 3.5.2284.0 C:\Windows\system32 6c2a0000 mscms.dll 6.1.7600.16385 C:\Windows\system32 6c570000 MSJINT40.DLL 4.0.9756.0 C:\Windows\SysWOW64 6c620000 mlang.dll 6.1.7600.16385 C:\Windows\system32 6d270000 AUDIOSES.DLL 6.1.7600.16385 C:\Windows\system32 6d880000 msi.dll 5.0.7600.16385 C:\Windows\system32 6dac0000 MPR.dll 6.1.7600.16385 C:\Windows\system32 6dae0000 wsock32.dll 6.1.7600.16385 C:\Windows\system32 6db10000 wdmaud.drv 6.1.7600.16385 C:\Windows\system32 6e840000 MSACM32.dll 6.1.7600.16385 C:\Windows\system32 6e860000 OLEACC.dll 7.0.0.0 C:\Windows\system32 6e8a0000 SXS.DLL 6.1.7600.16385 C:\Windows\system32 6ea90000 midimap.dll 6.1.7600.16385 C:\Windows\system32 6eaa0000 msacm32.drv 6.1.7600.16385 C:\Windows\system32 6eb40000 RICHED20.dll 5.31.23.1229 C:\Windows\system32 6ebc0000 AVRT.dll 6.1.7600.16385 C:\Windows\system32 6ebd0000 msiltcfg.dll 5.0.7600.16385 C:\Windows\system32 6ec00000 ksuser.dll 6.1.7600.16385 C:\Windows\system32 6ec20000 MFC90ENU.DLL 9.0.30729.4148 C:\Windows\WinSxS\x86_microsoft.vc90.mfcloc_1fc8b3b9a1e18e3b_9.0.30729.4148_none_4973eb1d754a9dc9 6ed00000 MMDevAPI.DLL 6.1.7600.16385 C:\Windows\system32 6ed70000 msimg32.dll 6.1.7600.16385 C:\Windows\system32 6f380000 ntshrui.dll 6.1.7600.16385 C:\Windows\system32 6f3f0000 PROPSYS.dll 7.0.7600.16385 C:\Windows\system32 6f9b0000 olepro32.dll 6.1.7600.16385 C:\Windows\system32 6f9e0000 slc.dll 6.1.7600.16385 C:\Windows\system32 6f9f0000 cscapi.dll 6.1.7600.16385 C:\Windows\system32 6fa00000 actxprxy.dll 6.1.7600.16385 C:\Windows\SysWOW64 6fb40000 gdiplus.dll 6.1.7600.16385 C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7600.16385_none_72fc7cbf861225ca 6fcd0000 winmm.dll 6.1.7600.16385 C:\Windows\system32 6fea0000 d3d8thk.dll 6.1.7600.16385 C:\Windows\system32 6feb0000 d3d9.dll 6.1.7600.16385 C:\Windows\system32 70ca0000 WindowsCodecs.dll 6.1.7600.16385 C:\Windows\system32 70fc0000 AcSignIcon.dll 18.0.55.0 C:\Windows\SysWOW64 71690000 dwmapi.dll 6.1.7600.16385 C:\Windows\system32 716b0000 uxtheme.dll 6.1.7600.16385 C:\Windows\system32 71730000 apphelp.dll 6.1.7600.16385 C:\Windows\system32 71780000 RICHED32.DLL 6.1.7600.16385 C:\Windows\system32 72130000 winspool.drv 6.1.7600.16385 C:\Windows\system32 74520000 comctl32.dll 6.10.7600.16385 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7600.16385_none_421189da2b7fabfc 74750000 rsaenh.dll 6.1.7600.16385 C:\Windows\system32 74a60000 POWRPROF.dll 6.1.7600.16385 C:\Windows\system32 74a90000 CRYPTSP.dll 6.1.7600.16385 C:\Windows\system32 74ce0000 RpcRtRemote.dll 6.1.7600.16385 C:\Windows\system32 74d60000 version.dll 6.1.7600.16385 C:\Windows\system32 74e60000 MSVCR90.dll 9.0.30729.4926 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc0e5a 74f10000 MSVCP90.dll 9.0.30729.4926 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4926_none_508ed732bcbc0e5a 75040000 ntmarta.dll 6.1.7600.16385 C:\Windows\system32 751c0000 srvcli.dll 6.1.7600.16385 C:\Windows\system32 75240000 profapi.dll 6.1.7600.16385 C:\Windows\system32 75250000 USERENV.dll 6.1.7600.16385 C:\Windows\system32 75440000 CRYPTBASE.dll 6.1.7600.16385 C:\Windows\syswow64 75450000 SspiCli.dll 6.1.7600.16385 C:\Windows\syswow64 754b0000 CFGMGR32.dll 6.1.7600.16385 C:\Windows\syswow64 754e0000 GDI32.dll 6.1.7600.16385 C:\Windows\syswow64 75570000 psapi.dll 6.1.7600.16385 C:\Windows\syswow64 75580000 ole32.dll 6.1.7600.16385 C:\Windows\syswow64 756e0000 CRYPT32.dll 6.1.7600.16385 C:\Windows\syswow64 75800000 WS2_32.dll 6.1.7600.16385 C:\Windows\syswow64 75840000 imm32.dll 6.1.7600.16385 C:\Windows\syswow64 758a0000 comdlg32.dll 6.1.7600.16385 C:\Windows\syswow64 75950000 MSASN1.dll 6.1.7600.16385 C:\Windows\syswow64 759c0000 KERNELBASE.dll 6.1.7600.16385 C:\Windows\syswow64 75a10000 WLDAP32.dll 6.1.7600.16385 C:\Windows\syswow64 75ba0000 ADVAPI32.dll 6.1.7600.16385 C:\Windows\syswow64 75d40000 oleaut32.dll 6.1.7600.16385 C:\Windows\syswow64 75dd0000 WINTRUST.dll 6.1.7600.16385 C:\Windows\syswow64 75e00000 NSI.dll 6.1.7600.16385 C:\Windows\syswow64 75e10000 DEVOBJ.dll 6.1.7600.16385 C:\Windows\syswow64 75e30000 CLBCatQ.DLL 2001.12.8530.16385 C:\Windows\syswow64 75ec0000 USP10.dll 1.626.7600.16385 C:\Windows\syswow64 75f60000 iertutil.dll 8.0.7600.16385 C:\Windows\syswow64 76160000 shell32.dll 6.1.7600.16385 C:\Windows\syswow64 76db0000 SHLWAPI.dll 6.1.7600.16385 C:\Windows\syswow64 76e20000 MSCTF.dll 6.1.7600.16385 C:\Windows\syswow64 76f80000 setupapi.dll 6.1.7600.16385 C:\Windows\syswow64 77120000 user32.dll 6.1.7600.16385 C:\Windows\syswow64 77220000 RPCRT4.dll 6.1.7600.16385 C:\Windows\syswow64 77310000 msvcrt.dll 7.0.7600.16385 C:\Windows\syswow64 773c0000 kernel32.dll 6.1.7600.16385 C:\Windows\syswow64 774c0000 sechost.dll 6.1.7600.16385 C:\Windows\SysWOW64 778b0000 LPK.dll 6.1.7600.16385 C:\Windows\syswow64 778e0000 ntdll.dll 6.1.7600.16385 C:\Windows\SysWOW64 processes: 0000 Idle 0 0004 System 0 0170 smss.exe 0 01d0 csrss.exe 0 0214 wininit.exe 0 0224 csrss.exe 1 024c services.exe 0 0264 lsass.exe 0 026c lsm.exe 0 02ac winlogon.exe 1 0308 svchost.exe 0 0354 svchost.exe 0 0390 atiesrxx.exe 0 03dc svchost.exe 0 0084 svchost.exe 0 0188 svchost.exe 0 0424 svchost.exe 0 0454 atieclxx.exe 1 04e4 svchost.exe 0 05ac spoolsv.exe 0 05c8 svchost.exe 0 0624 svchost.exe 0 0638 ApplicationUpdater.exe 0 0650 BCUService.exe 0 0674 des2svr.exe 0 06c4 LMIGuardianSvc.exe 0 06dc ramaint.exe 0 06f4 LMS.exe 0 070c LogMeIn.exe 0 0760 svchost.exe 0 0774 ccsvchst.exe 0 07bc svchost.exe 0 07d0 TimeMgmtDaemon.exe 0 04a0 IAStorDataMgrSvc.exe 0 0ac8 svchost.exe 0 0d24 taskhost.exe 1 normal 0d74 ccSvcHst.exe 1 normal C:\Program Files (x86)\Norton Internet Security\Engine\17.8.0.5 0de4 dwm.exe 1 high 0e18 explorer.exe 1 normal 0ed0 LogMeInSystray.exe 1 normal 0f18 soffice.exe 1 normal C:\Program Files (x86)\OpenOffice.org 3\program 0f2c IAStorIcon.exe 1 normal C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology 0f58 soffice.bin 1 normal C:\Program Files (x86)\OpenOffice.org 3\program 0f74 GUI.exe 1 normal C:\Program Files (x86)\GIGABYTE\ET6 0f8c openvpn-gui.exe 1 normal C:\Program Files (x86)\OpenVPN\bin 0fc4 MOM.exe 1 normal 0934 SharpTray.exe 1 normal C:\Program Files (x86)\Sharp\Sharpdesk 0930 FTPServer.exe 1 normal C:\Program Files (x86)\Sharp\Sharpdesk 0c68 jusched.exe 1 normal C:\Program Files (x86)\Java\jre1.6.0_07\bin 10ac nsapp.exe 1 normal C:\Program Files (x86)\Sharp\Sharpdesk 10b8 SearchIndexer.exe 0 1170 wmpnetwk.exe 0 12a4 CCC.exe 1 normal 1300 svchost.exe 0 0660 AlarmClock.exe 1 0630 jucheck.exe 1 normal C:\Program Files (x86)\Java\jre1.6.0_07\bin 14f0 PresentationFontCache.exe 0 16c8 VMWindow.exe 1 normal 0f28 vpc.exe 1 normal 0bc8 SearchProtocolHost.exe 0 1270 OUTLOOK.EXE 1 normal C:\Program Files (x86)\Microsoft Office\Office12 1184 splwow64.exe 1 normal 133c iexplore.exe 1 normal C:\Program Files (x86)\Internet Explorer 1698 iexplore.exe 1 normal C:\Program Files (x86)\Internet Explorer 12ec Sharpdesk.exe 1 normal C:\Program Files (x86)\Sharp\Sharpdesk 161c svchost.exe 0 1438 AcroRd32.exe 1 normal C:\Program Files (x86)\Adobe\Reader 9.0\Reader 1680 acad.exe 1 normal 14b4 FNPLicensingService64.exe 0 02f0 WSCommCntr2.exe 1 normal 0cf8 Aec32BitAppServer57.exe 1 normal C:\Program Files (x86)\Common Files\Autodesk Shared 034c audiodg.exe 0 1454 StormSanitary.exe 1 normal C:\Program Files (x86)\Autodesk\SSA Stand-Alone 2011 16dc SearchProtocolHost.exe 1 idle 16c4 taskeng.exe 0 17c4 SearchFilterHost.exe 0 idle stack dump: 0018f53c 92 cc 40 00 de fa ed 0e - 01 00 00 00 07 00 00 00 ..@............. 0018f54c 50 f5 18 00 92 cc 40 00 - b4 58 66 0c 8c bb 40 00 P.....@..Xf...@. 0018f55c 88 f5 18 00 00 00 00 00 - d8 f5 18 00 6c f5 18 00 ............l... 0018f56c f0 f6 72 0c 00 c0 7c 0c - e0 5f 2f 12 0f 03 41 00 ..r...|.._/...A. 0018f57c d0 f5 18 00 5e 56 40 00 - 04 00 00 00 e0 5f 2f 12 ....^V@......_/. 0018f58c 0b 4c df 00 e0 5f 2f 12 - 19 c0 54 00 00 c0 7c 0c .L..._/...T...|. 0018f59c d4 6d 67 0c 00 00 00 00 - 60 f6 18 00 e5 60 df 00 .mg.....`....`.. 0018f5ac 60 f6 18 00 e0 f5 18 00 - c4 4e 40 00 d8 f5 18 00 `........N@..... 0018f5bc d4 6d 67 0c 00 00 00 00 - 00 80 70 40 00 00 00 00 .mg.......p@.... 0018f5cc 00 00 00 00 00 00 00 00 - 00 00 00 00 64 f6 18 00 ............d... 0018f5dc dd 78 df 00 6c f6 18 00 - c4 4e 40 00 64 f6 18 00 .x..l....N@.d... 0018f5ec 9c 6f 51 00 00 c0 7c 0c - d4 6d 67 0c 00 00 00 00 .oQ...|..mg..... 0018f5fc 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 0018f60c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 0018f61c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 0018f62c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 0018f63c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 0018f64c 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................ 0018f65c 00 00 00 00 00 00 00 00 - e0 f6 18 00 15 9c de 00 ................ 0018f66c 2c f8 18 00 c4 4e 40 00 - e0 f6 18 00 3d 00 00 00 ,....N@.....=... disassembling: [...] 0054c007 -$13bd30 ($4102dc) ; SysUtils.StrToFloat 0054c00c f tbyte ptr [esp] 0054c00f 0054c010 loc_54c01d 0054c012 64 eax, ebx 0054c014 > -$13bd3d ($4102dc) ; SysUtils.StrToFloat 0054c019 f tbyte ptr [esp] 0054c01c 0054c01d f tbyte ptr [esp] 0054c020 67 esp, $c 0054c023 ebx [...]
hard luck steve, not sure what you did but looks like a text entry instead of number, though i could be completely wrong.
Anyway been finally using SSA since it's release over here. Great potential but again poor implementation;
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Wishes/Storm-and-Sanitary-Analysis-2011/td-p/2815754
Hi Dana,
the Autodesk Storm and Sanitary Analysis is a step into the right direction
and closes a big gap in Civil 3D's pipe networks.
However there seems to be a problem when exporting pipe data
via LandXML back to Civil 3D.
The LandXML file does not contain any design data, such as flow or velocity.
Is there a workaround or additional settings in SSA 2011?
Here is a snippet of one of my LandXML files.
Best regards
Frank Glatzel
Application Engineer - Civil / Structural
CADPLAN
Thanks for the reply...Yeah...I knew that but it was not showing up. We have determined that somehow our subscription got screwed up when we did some contract modifications before the end of the year. Hopefully this gets resolved soon.
