AutoCAD Civil 3D - Stormwater
Active Member
bbissinger
Message 1 of 3 (371 Views)
AutoCAD Civil 3D 2012 - Storm Sewers - Exceeding Pipe Capacity
371 Views, 2 Replies
06-14-2011 09:40 AM
Is it true that there is nothing in the program that tells us if we exceed pipe capacity or surcharge inlets?
Employee
Matt.Anderson
Message 2 of 3 (366 Views)
Re: AutoCAD Civil 3D 2012 - Storm Sewers - Exceeding Pipe Capacity
06-14-2011 03:03 PM in reply to: bbissinger
I would say, no, it's not true.
The HGL values being drawn above the pipe is a sure sign you have a capacity issue.  When the HGL appears above the RIM elevations (in profile or numerically), that would indicate you have surcharged inlets.
There are a couple other locations that I recall that provide Design Capacity and Actual Flow values, including the reports.
If you are seeking additional visual cues that an inlet is flooded or a pipe is under pressure, check out Autodesk Storm and Sanitary Analysis.
Matthew Anderson, PE
Product Manager
Active Member
bbissinger
Message 3 of 3 (362 Views)
06-14-2011 03:26 PM in reply to: Matt.Anderson
When you get a chance can you please provide me with the other locations for Design Capacity and Actual Flow Values? I am trying to get a good grasp on this and it seems to be difficult. We have started looking at SSA and are semi overwhelmed by all of the options and feel like there are so many options and we just don't understand how they interact with calculations. We are trying to dig into it though, but I am aware of the capacity feature in SSA.
