AutoCAD Civil 3D - Stormwater
Distinguished Contributor
millermccoy
Message 1 of 5 (541 Views)
2013 SSA Detention Pond Peak Outflow results
541 Views, 4 Replies
01-02-2013 09:54 AM
Attached is my 1st project using SSA for detention pond design.
Where is the best place to view the results for the detention pond peak outflow and maximum HGL?
Also, the program seems to separate the results per year storm...anyway to view the results for all year storms in the same report?
thanks!
how do you attach the .spf file?
2015 Civil 3D
Active Contributor
rdbrennan48
Message 2 of 5 (530 Views)
Re: 2013 SSA Detention Pond Peak Outflow results
01-02-2013 01:03 PM in reply to: millermccoy
I found it works best to put it in a .zip file and use the attachments function.
millermccoy
Message 3 of 5 (528 Views)
01-02-2013 01:06 PM in reply to: rdbrennan48
thanks
2015 Civil 3D
Employee
Matt.Anderson
Message 4 of 5 (515 Views)
01-03-2013 06:47 AM in reply to: millermccoy
The easiest method to view multiple results is to open each solution file within the Time Series Plot section.  In the time series Plot window, right-click and select Open Solution.  Open each storm's solution file, select the Nodes > Head value per solution file.
This provides you the graph and chart as shown below.  The summary table is shown when that appropriate element is selected.  The value you seek is the Maximum Head.
The outflow values would come from the orifice and weir elements. (or look at the E-1 node for the summation of both.)
Matthew Anderson, PE
Product Manager
millermccoy
Message 5 of 5 (508 Views)
01-03-2013 07:12 AM in reply to: Matt.Anderson
thanks...
anyway to print from the time series plot?
2015 Civil 3D
