Attached is my 1st project using SSA for detention pond design.
Where is the best place to view the results for the detention pond peak outflow and maximum HGL?
Also, the program seems to separate the results per year storm...anyway to view the results for all year storms in the same report?
thanks!
how do you attach the .spf file?
I found it works best to put it in a .zip file and use the attachments function.
The easiest method to view multiple results is to open each solution file within the Time Series Plot section. In the time series Plot window, right-click and select Open Solution. Open each storm's solution file, select the Nodes > Head value per solution file.
This provides you the graph and chart as shown below. The summary table is shown when that appropriate element is selected. The value you seek is the Maximum Head.
The outflow values would come from the orifice and weir elements. (or look at the E-1 node for the summation of both.)
