Civil 3D Forum
2013 - Is there a separate install for SSA?
4 REPLIES 4
651 Views, 4 Replies
I get the following message when I try to access it from the menu.
"EditInSSA cannot be used because the optional feature is not installed on this machine"
When I look to modify a deployment I cannot find the option to add SSA.
4 REPLIES 4
wfberry
From Brian Hailey's Blog:
http://civil3dplus.wordpress.com/2012/04/04/install-tip-want-everything-civil-3d-2013/
Look at the first picture.
Bill
pmcatnip
Thanks for the link.  I just tried a local reinstall of Map 3D 2012 and couldn't find a check box for SSA anywhere.  It's supposed to be the same in Map & Civil.  Any thoughts?  Would that part be done during the network install or the local install?
Dell Optiplex 360, Intel Core 2 Duo CUP, E7500 @ 2.93GHz, 3.00 GB RAM. Win XP Pro 32 bit. ACAD Map 3D 2012.
in reply to: pmcatnip
So that link explains how to install a stand alone but can you create a deployment with the SSA install set up?  If I'm installing Civil 3D from a deployment how would I add SSA or Sub-Assembly Composer?
pmcatnip
Found another link with pictures of the installation.  I'm amazed that with so many people using SSA the installation info is this difficult to find.
http://upandready.typepad.com/up_and_ready/2012/10/civil-3d-2013-where-is-storm-sanitary-analysis-su...
Rail Community
