Comunidade
I can change the Alignment station's label standard format to a brazilian/DNIT format, but I can't do the same on Profile View.
Does anyone have way to do it?
You can take a batter problem's notion ate the attached image.
Hi Bruno,
Follow the steps:
1. Select the data from bands and right-click after select "DataBands" option like below:
2. Click "Compose Label" and inside "Layout" select "..." on the field "contents":
3. Use the "Station Index Format".
Press OK all screens. Is done. Below I left the file for loading of version 2015.
Good Luck!
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
