Caríssimos, boa tarde!
Recebi um arquivo de pontos mas não consigo inserí-los no Civil 3D.
Alguém poderia me dar uma luzinha com relação à este "problema"?
Estes dados foram coletados por estação total e até que eu saiba, eram tratados no Topograph porém este, não recebeu tratamento nenhum.
O Civil reconhece este tipo de dado? Como fazer??
BOA VISTA 3.txt
BV-10;,S1-AUX;7778106.3750;471513.2590;885.439;
1;,IP,LO,CO12,PL0-CRISTA;7778092.2530;471520.3550;885.538;
2;CRISTA;7778096.2690;471520.5950;886.019;
3;CRISTA;7778097.7910;471518.8380;885.932;
4;,FP,CO12,PL0-CRISTA;7778097.8920;471518.3110;885.867;
5;P-COTA;7778090.5600;471530.5950;887.100;
6;P-COTA;7778095.8660;471531.9980;888.281;
7;P-COTA;7778102.7820;471533.2820;889.874;
8;P-COTA;7778108.5110;471536.4500;891.874;
9;,IP,LO,CO12,PL0-CRISTA;7778129.5130;471508.9490;887.905;
10;CRISTA;7778097.8120;471518.2900;885.812;
11;CRISTA;7778097.6470;471513.6620;884.196;
12;CRISTA;7778101.3620;471510.4580;883.751;
13;CRISTA;7778107.7930;471510.1090;884.471;
14;CRISTA;7778113.5180;471509.5260;885.115;
15;CRISTA;7778118.6550;471508.1790;885.675;
16;,FP,CO12,PL0-CRISTA;7778124.7880;471507.5910;886.686;
17;,IP,LO,CO10,PL1-PE;7778128.8770;471507.1200;887.336;
18;PE;7778132.9460;471504.8380;886.771;
19;PE;7778128.1390;471505.4860;886.055;
20;PE;7778121.4130;471506.6360;885.188;
21;PE;7778115.3360;471507.7040;884.459;
22;PE;7778108.2240;471508.8550;883.755;
23;,FP-PE;7778102.2770;471509.6210;882.493;
24;,IP,LO,CO12,PL0-CRISTA;7778099.0490;471509.8980;881.655;
25;CRISTA;7778122.4570;471498.3080;883.381;
26;CRISTA;7778119.1310;471500.4530;883.587;
27;CRISTA;7778115.9650;471502.1320;883.490;
28;CRISTA;7778110.3580;471504.5980;883.355;
29;CRISTA;7778105.2010;471506.1250;883.257;
30;CRISTA;7778100.0900;471508.2080;883.043;
31;CRISTA;7778100.6800;471508.6910;883.225;
32;CRISTA;7778106.0510;471508.2840;883.799;
33;CRISTA;7778113.1480;471507.1810;884.763;
34;CRISTA;7778116.8270;471506.1670;885.018;
35;,FP,CO12,PL0-CRISTA;7778121.7460;471505.9510;885.665;
36;,IP,CO4,PL4-CERCA;7778128.6730;471504.8730;886.431;
37;CERCA;7778098.6120;471515.7580;885.059;
38;CERCA;7778103.3490;471512.7130;884.798;
39;CERCA;7778109.5870;471509.5810;884.392;
40;CERCA;7778111.5200;471508.4200;884.219;
41;CERCA;7778113.7010;471507.2460;884.585;
42;CERCA;7778117.8020;471505.1650;884.838;
43;,FPCERCA;7778122.3890;471502.6410;884.871;
44;,IP,LO,CO0,PL5-FERROV;7778123.6990;471501.7770;884.577;
45;FERROV;7778089.6520;471509.3270;881.652;
46;FERROV;7778095.2240;471506.5080;881.633;
47;FERROV;7778102.9060;471502.6430;881.752;
48;FERROV;7778110.3760;471498.8260;881.867;
49;FERROV;7778137.0580;471485.3600;882.292;
50;FERROV;7778140.0800;471482.5750;882.470;
52;,FP-FERROV;7778088.5310;471508.6830;881.655;
Obrigada e FELIZ PÁSCOA À TODOS!!!!
Adriana.
Solucionado! Ir para Solução.
Adriana,
os dados das colunas estão separados por ponto e vírgula,
utilize o comando SUBSTITUIR no Bloco de Notas ou no Word para substituir ponto e vírgula por ESPAÇO.
No Civil 3D, na hora de escolher o formato de pontos a ser importado, escolha um formato compatível com o do arquivo que você enviou em anexo.
Uma dica, abra o arquivo no Excel e reordene as colunas para ficar no formato PNEZD (separado pro espaço). P - nº do ponto, N - coordenada Norte, E - coordenada Leste, Z - elevação, D - descrição do ponto. Também separe os pontos de controle BV-10, por exemplo em um arquivo separado e coloque o valor BV-XX no campo da descrição ao invés do campo de número, caso contrário, o C3D emitirá uma mensagem de erro.
Daniel, muito obrigada pela dica.
Aqui, esses pontos foram coletados da estação Leica 407.
Para evitar este transtorno o ideal seria descarregar a estação no próprio Civil para ele reconhecer os dados, correto?
Para evitar este pequeno trabalho.
Mas é isso,
Muito obrigado e tenha uma ótima semana!!!
Att,
Adriana
Não encontrou o que está procurando? Pergunte à comunidade ou compartilhe seu conhecimento.
