Civil 3D Forum
zoom and pan cause sticky mouse c3d 2012
15 REPLIES 15
Message 1 of 16
patrickk17
2653 Views, 15 Replies
After zooming or paning in a drawing the mouse pauses or sticks for a second then the curor moves fine until the next pan or zoom.  Is there a setting to fix this?
Happens on several machines in our office.
Windows 7 64
intel quad core q9300
8 gb ram
9800 gtx video
civil 3d 2012 64x
Tags (1)
15 REPLIES 15
Message 2 of 16
LyleHardin
in reply to: patrickk17
Check the toggle buttons at the bottom of the screen....
Check to make sure Selection Cycling is off. That'll bog things down. Turn Transparency off too.
Not sure if this is the problem, but it's what I would check first.
Lyle
Message 3 of 16
hgohel
patrickk17
I believe you may be running into this issue about layers/xrefs.  We have logged a defect about it.  Some suggestions have been posted by Sinc in that thread too, please try that out.
Himanshu Gohel
Autodesk, Inc.
Message 4 of 16
klugb
Himanshu,
Can you expand on the know issues? I have noticed the issues with reconciling layers, but we have another file that has to have all the xref's detached (unload doesn't work) before the delay/lag goes away.
Bruce Klug, P.E.
AutoCAD Expert Elite Alumni
AutoCAD Civil 3D Certified Professional
Civil 3D 2023.2.1
Win 10 Enterprise, 64-bit
Message 5 of 16
patrickk17
We have "layerval" typical set to 1.  I opened a drawing with xrefs that had the sticky mouse issue.  Changing layereval to 1 or 0 made no difference even after reconciling all the layers.  The problem remained even if the xrefs were unloaded, however, if the xrefs were detached the problem went away.
Message 6 of 16
klugb
That sounds similar. Some files work good after reconciling layers some need to have the xref's detached.
ADSK- We have opened each file that is xref'd and Audit/purge/purge reg apps/reconciled and saved, so they are all good clean files.
As for the layereval 0 Vs. 1, it only needs to be turned on to see which layers need to be reconciled. With it off you don't see the list of layers in the dialog box.
Bruce Klug, P.E.
Civil 3D 2023.2.1
Message 7 of 16
patrickk17
The hotfix
"autocad2012_performanceslowdown_hf_64bit"
fixed the problem.
Thanks Autodesk
Message 8 of 16
LyleHardin
Well,
It took me a while to find this hotfix....
Here's the link.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17013122&linkID=9240698
Message 9 of 16
theminiguy
in reply to: LyleHardin
I have SP1 on my C3D 2012, and the version of the .dll files is current to the hotfix, yet i am still having the same issue?
~~Laptop~~
Quad Core 2.3GHz Intel, 64-Bit, Win 7
16GB Ram, 2GB Graphics Card
256GB SSD
~~AU2009 Speaker~~
CV314-5: AutoCAD® Civil 3D® Design Straight Out of the Box: Going Where the Design Wizards Can't Always Go .....
Message 10 of 16
hgohel
in reply to: theminiguy
Hi Paul,
Could you clarify if I am understanding your situation:
1. You had C3D2012 + AutoCAD performance hotfix installed to resolve the cursor stickiness problem being discussed in this thread.
2. You updated to C3D2012 SP1, and the problem re-started?
Thanks.
Himanshu Gohel
Autodesk, Inc.
Message 11 of 16
LyleHardin
We've also noticed if you turn off running osnaps, it speeds things up in a busy Civil 3D drawing. This doesn't seem to be an issue with plain AutoCAD. I don't recall (on this particular user) if the .dll hot fix was applied or not. But, turning off the running Osnaps definitely sped things up (stopped the cursor jerks) even when a command was not active.
Message 12 of 16
bkanther
ADSK
Performance hotfix was installed. Stick Mouse was fixed.
SP1 installed sticky mouse is back!
Please help!!
Regards
Brad
Message 13 of 16
Jeff_M
in reply to: bkanther
Brad, see this post:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/2012-Hotfixes-not-included-in-C3D-SP1/m-p/3254638/hig...
But read all of the replies before you follow the directions....
Jeff_M, also a frequent Swamper
Message 14 of 16
bkanther
To clarify this.
Sticky mouse (pan command stuck) only happens when inside a paperspace viewport.
More interestingly if the viewport is locked and sticky mouse occurs and I move my cursor out of the drawing display area it will move the viewports dispaly origin even though it is locked!!!!!!
Regards
Brad
Message 15 of 16
bkanther
Lol sorry Jeff jsut read your post.
Hilarious Thanks
Brad
Message 16 of 16
theminiguy
in reply to: hgohel
Himanshu,
I had previously only applied SP1, i then did all the HOTFIXes as per this post, but as you see there are issues with this also:
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/2012-Hotfixes-not-included-in-C3D-SP1/m-p/3255278/hig...
~~Laptop~~
256GB SSD
~~AU2009 Speaker~~
Rail Community
