I have a client who is using 2008 civil 3D Land desktop companion. When he wants to label a line with degrees minutes and seconds or using the survey units with a precision of 0d, 0’, 00”he wants to be able to have the zero suppression activated. In other words if he has a line that is 0.0208 he wants that 0 + the period To show up at the beginning of the number and it is not doing that. I have walked him thru setting up the units, and it still does not work. Do you have any idea where you can set this 0 suppression in land. 2007 will work but not 2008.
Thanks for any help that you can give.
