Civil 3D Forum
Z distance in inches not feet
7 REPLIES 7
Message 1 of 8
ajfernandes
2266 Views, 7 Replies
I have a very simple surface. All of the elevations defining it, are set in feet. When I click on the surface it tells me my max and min elevations are in feet matching the points that I have defining the surface.
Here is the kicker, when I run a distance it is measuring the Z distance in inches and not feet. As you can see by the attached image the distance is 95' but the elevation change is 1 3/8".  The actual points defining the surface are 1.28' difference. If I were to do a spot elevation on the surface, it would give me the correct elevation in feet.
Can anyone tell me whats going on? I am guessing that this is some sort of variable that I have missed, but damned if I can find it.
Thanks in advance for your help.
7 REPLIES 7
Message 2 of 8
troma
in reply to: ajfernandes
Try setting your units to decimal feet rather than feet & inches.
Mark Green
Working on Civil 3D in Canada
Message 3 of 8
ajfernandes
in reply to: troma
Unfortunately that didn't work. It just changed my measurements to inches instead. But kept the z measurement the same.
Any other ideas?
Message 4 of 8
troma
Can you repeat the screen shot with the new units setting?
Mark Green
Message 5 of 8
ajfernandes
in reply to: troma
Here is a screen shot of the units set to decimal instead of architectural.
Message 6 of 8
troma
I've always worked in metric so I don't really know how the imperial settings work in C3D, but I know that it is always meant to be feet, not inches.  It looks like all your distances are off by a factor of 12, so you may have started up wrong from the begining, I don't know.
Could really do with someone else jumping in here to help, but unfortunatly when the topic is marked as solved others may not look into it.
Mark Green
Message 7 of 8
ajfernandes
in reply to: troma
Your advice lead me to the solution. Our office has been bouncing back and forth between imperial and metric and I don't have enough experience to do this successfully.
Here is the solution. Autocad wants the drawing in Decimal Feet. I went back and scaled down the drawing by 12 so that all measurements of units were in feet. (I.E. 9.50' instead of 9'-6") Now scaling the drawing also scales the Z elevation so I had to follow the following link to redifine my points after I scaled. See this thread for how to do that (http://www.civil4d.com/2009/10/scale-your-points-keep-the-elevations/)
And now, everything makes sense again.
I'll have to reset my viewports, but small price to pay.
Message 8 of 8
AllenJessup
Make sure that you are setting your units correctly in the Drawing Settings. Go to the Toolspace and on the Settings tab - Right click on the active drawing and select, Edit Drawing Settings. Set up your units on Units and Zone tab and check 'Set AutoCAD Variables to match'.
Here is how I have mine set up for feet
Allen Jessup
Engineering Specialist / CAD Manager
Rail Community
