Guerra dos Santos wrote:
> Hello. In Portugal, we need to export data from a full alignment
> (every each 25 meters) in the form of a table with five columns:
> Station Value, X coordinate, Y coordinate, Z value (from de profile),
> Direction (in grads). Is there any XSL file to do that, or does civil
> 3d do it in any other way ? Thanks.
Unless you write some script code in your XSL file, this isn't available
at the moment. However, another approach might be to write some VBA
code that samples the alignment every 25m as you require, and write that
out to a file.
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
