Valued Contributor
pserpas
Message 1 of 8 (2,121 Views)
XREFs will not display
2121 Views, 7 Replies
09-13-2011 05:42 AM
Many times when I try to attach a xref and do a zoom extents, I cannot find the drawing.  I change my limits to -999999,-999999 and 999999,999999 but still nothing.  This seems to be a random problem.
Pat
Windows 7 x 64
Nvidia GeForce GTS 450
8 GB Ram
Intel Core i5-2310 @ 2.90 GHz
v. F.107.0.0 AutoCAD Civil 3D 2012 SP1
If you have drawing A with C3D objects in it (such as a Surface), you then open drawing B and Xref A as on overlay. Now add some surface labels for the xref'ed surface in A. If you now try to Xref B into a drawing C, you will have broken labels sinc ethe overlay'ed drawing A is not available for the Labels in B to update from....make sense? So now in C you will have these "broken reference" labels all at 0,0, and if the drawings themselves are at normal State Plane coordinates of say 300,000/1,000,000 then a zoom extents will not appear to display anything since these objects will be too small to see. Try selecting with a crossing selection near 0,0 and you will likely find the culprit.
Strakan
Message 2 of 8 (2,092 Views)
Re: XREFs will not display
09-13-2011 10:34 AM in reply to: pserpas
Two things I can think of:
Check to make sure your XREF is on the zero Layer or
Type Options, and under the display tab, turn your XREF fade control to -90.
Jeff_M
Message 3 of 8 (2,087 Views)
09-13-2011 10:44 AM in reply to: pserpas
New Member
bdevineni
Message 4 of 8 (1,743 Views)
01-04-2013 10:16 AM in reply to: pserpas
I do have the same trouble. I have a drawing "A" with limits 0,0 to 36,24. I am trying to attach this drawing to a layout of dwg "B". I can see it in reference diaglog box, but I dont find it in layout. I checked all other options like layer on, fade -90, everything is ok. I did quickselect xref and It is selecting the ref "A" with a grip point at 0,0. But I dont see it.
However, I had xrefed again in model. I find it attached at different location coordinates -2960277.4188,-13825882.14. But the insertion point in properties shows me 0,0,0 and scale as 1.0.
Can anyone suggest me how to correct this bug?
troma
Message 5 of 8 (1,739 Views)
01-04-2013 10:38 AM in reply to: bdevineni
Welcome to the forums.
You're generally better off starting a new thread than adding to an old one with a new question.  I don't think your problem is related.  You can't x-ref a drawing into a layout, paperspace, as far as I know.  Try inserting it as a block instead.
I don't quite follow the problem you had with x-reffing into model.  Let me ask you: is drawing A drawn in model or paper?  You can only x-ref what is in the model space.
Credit where credit is due! Give kudos or accept as solution whenever you can.
New Member
bdevineni
Message 6 of 8 (1,728 Views)
01-04-2013 11:50 AM in reply to: troma
Actually we can xref a drawing A (which is drawn in model) to paperspace of dwg B. I always do that for titleblock.
The drawing which I draw is in model space with limits 0,0 and 36,24. When I xref it in dwg B - it is not inserting at 0,0. It is inserting at -2960277.4188,-13825882.14. which is far away. I units are matched, which is feet (both dwgs). I dont know why it is not inserting at 0,0.
Joe-Bouza
Message 7 of 8 (1,727 Views)
01-04-2013 11:51 AM in reply to: troma
Yes you can. I do it all the time for key maps.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
troma
Message 8 of 8 (1,723 Views)
01-04-2013 12:07 PM in reply to: Joe-Bouza
Well there you go, always something new!
