Civil 3D Forum
XRef shading for visibility....Need to see the XREF....Help!
5 REPLIES 5
ODG_PLS
14180 Views, 5 Replies
Every time I attach an XREF file, the xref drawing is shaded and is very difficult to see.  Please help this frustrated Surveyor that is not a happy camper, having looked through a good deal of the COMMANDS & properties trying to make Xref's more visible, without binding them into my original drawing.  Thanks!
5 REPLIES 5
michael.robertson
in reply to: ODG_PLS
xdwgfadectl controls the amount of fading (0 for no shading, upto 90 for almost invisible).
You can also use TRANSPARENCYDISPLAY to set whether transparency are displayed or ignored.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
ODG_PLS
in reply to: michael.robertson
Thanks, Michael!  That did the trick!
ODG
10acken
tHERE IS ALSO A SLIDER IN THE OPTIONS as of 2010 to control this.
MaddCatter
in reply to: 10acken
Can you tell me what tab this is under in the options?
MaddCatter
in reply to: MaddCatter
Ok.
I found it.  It was under the Display Tab
Located in the lower right under Fade Control
Set the Xref Display to 0
Rail Community
