Civil 3D Forum
Xref Layer Color (Back to original color)
13 REPLIES 13
Message 1 of 14
JBR-1
38252 Views, 13 Replies
Is there a way to revert back to the original colors of an xref besides having to reattach the xref and purging the DWG.
I always change the colors of the projects Existing site/utilty XREF to color 252 to shade it back to have the proposed show up darker. But I try to select all layers to change the colors back to what they were before and the box to set color by layer is not available.
Thank You
13 REPLIES 13
Message 2 of 14
Ed.McGriskin
in reply to: JBR-1
If the layer colors are set correctly in the xref, you could use the visretain setting to reset back to those colors.
Ed McGriskin, P.Eng.
Project Engineer @ HUSSON
Remember to accept the solution so others can find the solution also.
Message 3 of 14
Jay_B
in reply to: JBR-1
Temporarily set VISRETAIN to zero.
Reload the Xref's you want to inherit the Xref drawing color settings.
Change visretain back to 1 so any additional color assignments in current drawing are maintained.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 14
troma
in reply to: Ed.McGriskin
Careful with that, VISRETAIN will also set all layers to whatever state they are in in the x-reffed drawing— ON/OFF FREEZE/THAW settings etc.
So perhaps the best way is to save a layerstate as is in your drawing, but don't save 'color ' in the layerstate. Then switch VISRETAIN to 0, reload the x-ref (or close the drawing and reopen it), and switch VISRETAIN back to 1 again. Then restore your layerstate so your layers are set as you need them, and just the colours will reflect your x-ref.
Mark Green
Working on Civil 3D in Canada
Message 5 of 14
Ed.McGriskin
in reply to: troma
Good point troma. I typically don't have layers that I freeze/turn off in my base xrefs which is why I forgot to mention that.
Message 6 of 14
troma
Another option I have sometimes used it to set the colours for some objects individually, not ByLayer.  Typically I will do this if it is something simple that I need to change the colour of, and I don't want to go through 15 drawings changing the layer colour or messing with VISRETAIN.  If you do the colour this way it will automatically propagate to all drawings that reference it—because the colour is not ByLayer it ignores the colour setting for the layer in the host drawings.
Mark Green
Message 7 of 14
pmhisha
in reply to: JBR-1
Thanks its very usefull
Message 8 of 14
pmhisha
in reply to: troma
Thanks its very useful. may i know how to save layerstate without color?
Message 9 of 14
troma
in reply to: pmhisha
@pmhisha expand out the dialog box and choose the setting you want to use before hitting 'Save'
Mark Green
Message 10 of 14
galvandelima
in reply to: JBR-1
Just Had this problem using FDOT Template
To change this setup, go to Layer Properties, click on setting right at the upper right corner of the window and change xref layer settings from don't retain overrides to refer layer properties to retain overrides.
Message 11 of 14
curtisclark
in reply to: JBR-1
I think this is what you are looking for (link below, post #10):
https://forums.autodesk.com/t5/civil-3d-forum/visretain/m-p/9207520/highlight/true#M413377
It is a function called 'Reset Xref Layer Properties' and is a quick way to reset xref layer properties to those of the base drawing, without affecting viewport overrides (something VISRETAIN can't currently accomplish in any state).
Check it out and let me know if it helped you!
Message 12 of 14
kira.hunt
in reply to: curtisclark
This solution doesn't appear to work in CAD version 2018 - but I found something that does.
I opened a blank CAD file and xrefed my base into it and then created a layerstate from this file in modelspace (note: no overrides in the layerstate).  I exported that layerstate.  Then open my original file that has the xref with layer colours overriden.  In modelspace, I import the new layerstate I just created.
And voila - my modelspace is correct again, but all of my viewport overrides stay as is.  It's kind of annoying, but simpler than the VISRETAIN route where I have to re-freeze layers and fix layerweights etc in every viewport ever.
Message 13 of 14
mariomtzb89
in reply to: troma
gracias, me fue de gran utilidad.
Message 14 of 14
lilyflanigan
in reply to: JBR-1
In the layer properties manager, expand Xref node, right click the file you want to revert back to original colors, hover over Reset Xref Layer Properties, select Color. The colors will revert back to original colors assigned in the Xref file. Just discovered this myself, very simple after all!
Rail Community
