I have read a few posts about others having this happen. I'm trying to get a handle on what should and should not be expected to work as far as labeling XREF'd entities goes. I'm using 2011.
I have recently had bearing notes associated with an XREF'd line disappear, and I can't pinpoint the cause.
I had edited a couple of lines in said XREF'd drawing, but NOT the one that was associated with the C3D notes. There are two C3D drawings that XREF this drawing and that have line labels applied to the same, unchanged, line. Yet, all of those labels were gone (in both drawings) when I opened them this morning.
So, should labeling an XREF'd entity work? Are labels predicably lost when a labeled line undergoes a known set of modifications (Sinc relayed his experiences here: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Xref-labels-not-dynamic/m-p/2886718/highlight/true#M1...
What if the XREF'd drawing is simply saved, with no changes made to a labeled line? Should that be okay?
If labeling XREF's is known to be unpredictable, it sort of puts us back to manual text labels and manual curve tables. Is that really what people are having to do?
Thanks for your comments.
This is not a problem anymore on Civil 3D 2017 with SP1. It will be a problem if you have mixed environment with some users with native 2017, and some users with SP1.
NB: the latest update brings you to SP1.1, also not a problem.
That is great news! Since this will be the last project I have in C3D 2015, and plan on using 2017 going forward, it shouldn't be a problem for me.
And the problem is back... Using C3D 2019.1 Update and corruption occurs when the following is true:
All three have to happen. To work around the issue, once you create a table in your drawing, do not RELOAD any XREF. If you need to reload, save the drawing, close, and reopen.
So glad Autodesk fixed this issue, then broke it again...
I can confirm, a client of mine is experiencing this problem again as well. 2019.1 XREF Tag's broken again.
I to am experiencing this issue. I have losted my labels serval times and it is very frustrating. Can someone please fix this, Thank you
Yes. Also experiencing this issue (again). At least I'm sure Autodesk must know how to fix it again. I just hope it doen't take them too much longer.
We are having the same issues with labels for parcels on the file xref'ed in to our plats.
We are experiencing the same.
Latest updates installed:
Civil 3D 2019.1
AutoCAD 2019.1.2
Opened a case # 1455565 and it was sent to devs case # CIVIL-22056, which means I will probably never hear back until an actual patch or update is released.
Please submit your own cases and you're welcome to refer to my case numbers - this really needs to be fixed!
@JimsTools wrote:And the problem is back... Using C3D 2019.1 Update and corruption occurs when the following is true:
- Tag lines or curves from an Xref.
- Create a Table.
- Reload an Xref (doesn't even have to be the one that is labeled).
I am very sorry to say I have not gotten any updates from Autodesk, nor have I found a fix for this.
We submitted a case referencing this case number, and received a call from autodesk, indicating it was a known issue, has been sent on the line and won't be contacted again other than when the issue is resolved. No timeline provided, so it does not seem like a priority to the dev team to resolve. When I told them this was delaying my company wide deployment of the 2019 product, they suggested going to the 2018 product instead. Pretty disappointing. And I feel like because they have moved everyone to subscription, they have weakened the end users rights.
Thanks for this input. Autodesk suggested that since this issue was holding up our deployment of 2019, that we might entertain the idea of upgrading to 2018 instead. Glad we did not waste our efforts there.
Bump this back to the top. Installed latest updates and tested.
Still not fixed!
Product version: 13.0.1175.0 Civil 3D 2019.2 Update
Built on: P.162.0.0 AutoCAD 2019.1.2
22.0.022.16 Autodesk AutoCAD Map 3D 2019.0.1 Update
8.1.48.0 AutoCAD Architecture 2019
We are also having this same issue. We had the issue in C3D 2018 with all updates installed, and migrated to C3D 2019 and also have this issue with all updates installed as of 1/30/2019. Autodesk please prioritize critical bugs like these and create hotfixes rather than making us wait for service packs, and give us progress so that we know a fix is coming at least, even if you can't give a specific date. This is bad customer service.
I heard the following from Autodesk back on 11/29/18:
"The development team started working on a tech assessment last night (Defect ID is CIVIL-22056).
Will provide more updates as I get them. Hopefully this can get resolved quickly.
Thank you,
Ian
More detailed information from Autodesk all:
“Regarding CaseNo:14799212, our development team has isolated the issue, which was introduced and subsequently fixed by the ACA team. They integrated the fix into Civil 3D 2018.3 build 1423.0 on 1/10. As of now we are targeting the release of 2018.3 for late February or early March. There are a few options for delivering this fix to the customer. We confirm its fixed and ask the customer to wait for the release of 2018.3, we can update the futures portal with a new 2018.3 beta for the customer to trial or we can distribute the loose files directly. Distributing loose files can be problematic so its best we do not distribute them unless it is absolutely necessary.”
Please reach out to me if you would like to get the beta and I'll see what I can do...
Ian Donovan
iand@theppigroup.com
503-231-1576
PPI Group, a Topcon Solutions Store
Thank you for the info, that is greatly appreciated. We are now on Civil 3D 2019. Do you have any information on when an update will be available for that version? If it is the same case, I am comfortable with loose files and manually installing them if necessary.
Hi Jesse,
I am told once the fix comes out for 2018.3 that it will also be applicable to the 2019 version. Time-frame for public hot fix release is Late February/March 2019.
-Ian
