Civil 3D Forum
xref coming into wrong position
3 REPLIES 3
asloat
1930 Views, 3 Replies
Another strange CAD issue; Civil3D 2012
I have two drawings, lets call them GR and LM.
I can xref GR into LM and everything is correct. If I xref LM into GR however, LM appears in the wrong spot down near 0,0. If I copy base point a line out of LM, it inserts correctly into GR using 0,0.
Both drawings contain other xrefs, but all are overlayed, so they don't carry forward. If I xref one of LM's xrefs into GR it appears in the right spot.
I have checked and both LM and GR are set to world UCS, no datum, and USfeet, correct units. I have compared their x/y locations and both are correct as well, just LM xrefs completely into the wrong spot.
I can of course force it into the right spot with a move command, but this is not ideal as the project spans years and having to do this each time is a pain.
3 REPLIES 3
Jeff_M
in reply to: asloat
What is the BASE value for LM? (normally 0,0,0 for what you want to be doing)
asloat
in reply to: Jeff_M
There we go, the drawing had a BASE not 0,0   No idea how it was changed, no one here would normally have a reason for doing so.
Thank you!
bcsurvey
in reply to: asloat
I think it normally happens when someone gets into a coffee-induced click-fest (like we all do) and grabs the wrong object to move/drag.  The good thing is that you do have that insertion basepoint control, so that an issue like that can be easily remedied.
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
Rail Community
