I have a problem that I hope I can get help with.
I have a civil3d file with featureline labels, with a standard plus symbol at the location.
The problem is that when i xref ttihs file into a n autocad drawing, the plus will not show up in viewports and does not print. The unusual thing is that it does show up in model space in the drawing
See attachements (ignore line thickness)
Can anyone help fix this?
Is the Civil 3D Object Enabler installed? If the + was created on Layer 0. Is 0 Off or Frozen in the drawing?
Allen
Allen Jessup
CAD Manager - Designer
First, I would delete the viewport and recreate it. I have seen them become corrupt with strange results.
Second, Can you post the C3D drawing so we can xref it to test?
It's a marker from Civil 3D I bet. If you can see the text but not the marker check the Show Annotation Objects symbol down in the status bar by your scale selections. It should be blue or On. If it's gray then that's the problem, turn it on and all the objects should show up.
Heidi
