Valued Contributor
jbalaneski
Message 1 of 9 (470 Views)
XREF C3D drawing for Profiles & Annotation Text
470 Views, 8 Replies
05-07-2013 07:48 AM
I am trying to XREF my C3D Design file that has my profiles and sections in it into a drawing with a title block and viewport.  Everything is fine in Model Space...but when I create the viewport in Paper Space none of the annotative text of the profile/section shows up...or is microscopic.
I did this once on a project before and it worked fine...but now it seems to not participate.  Any help would be appreciated.
Have you checked this setting?:
Valued Contributor
jbalaneski
Message 2 of 9 (469 Views)
Re: XREF C3D drawing for Profiles & Annotation Text
05-07-2013 07:51 AM in reply to: jbalaneski
I have also created a separate drawing XREF and used data shortcuts to bring in my profiles/sections into that drawing and applied the proper profile/section view styles.  And everything is fine in model space.  But once I XREF that drawing into my working drawing and go to layout space...none of the text is showing up.  I've tried switching all my annotative properties on and off in every drawing..and nothing seems to be working.  I think it's a viewport issue.
Distinguished Contributor
t_mckenzie
Message 3 of 9 (462 Views)
05-07-2013 07:57 AM in reply to: jbalaneski
Check the annotation scale (not the standard scale) of the viewport in the properties dialog box. Sometimes that gets messed up and needs to be reset.
-Tucker
Valued Contributor
jbalaneski
Message 4 of 9 (453 Views)
05-07-2013 08:25 AM in reply to: t_mckenzie
Thought of that already...and still nothing.  This is super frustrating!  What's the point of having dynamic design capabilities in drawings if you have to explode everything and manually update it like it was 2005!
Valued Contributor
jbalaneski
Message 5 of 9 (452 Views)
05-07-2013 08:27 AM in reply to: jbalaneski
I have also checked all the unit settings to all be set to METRIC and METRES...even the one in the Prospector.
Hammer.john.j
Message 6 of 9 (440 Views)
05-07-2013 10:29 AM in reply to: jbalaneski
you need to use data shortcuts and create new views in your sheet drawing, is the simple answer.  you also need to data ref the ex. surface, AND create a new profile from surface OF that ex. surface to avoid dashed lines from appearing to have linetype generation turned off.
there are all sorts of funny problems with plan/profile sheets because of the profile essentially doesn't like to be annotated or dealt with via xref.
if you intent to annotate your profile in sheet drawings, better make sure you've got that sorted out before you cut up the profile into sheets, because well i doubt i need to explain it.
John Hammer, LA
Dell Precision T3500 - Xenon W3550 @ 3.07 (4 core)
Ram @ 12Gb
64bit Win7 Pro
Samsung SSD
NVIDIA Quadro 2000 - Dual Monitors
Cat 6 network with GlobalScape Avail Agent - WAFS
Infrastructure Design Suite Premium and Civil 3D 2012 & 2014
troma
Message 7 of 9 (438 Views)
05-07-2013 10:35 AM in reply to: jbalaneski
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Contributor
jbalaneski
Message 8 of 9 (424 Views)
05-07-2013 12:20 PM in reply to: troma
Thanks Troma! That fixed it....that is just ridiculous!  I'm going to make a note of that for future reference!
troma
Message 9 of 9 (419 Views)
05-07-2013 12:40 PM in reply to: jbalaneski
It annoys me too, happy to share.
