I have an xref-ed alignment that shows all the station lables in the correct direction however two station lables (sta.4+50 and 5+00) are in upside down. how could i fix tihs issue and what may be causing it. see the attachment for the view.
thank you,
this might be a wrong guess, but in your alignment station label style, under the GENERAL tab, if you set your PLAN READABLE to FALSE, does that solve your problem?
