Civil 3D Forum
XREF a DGN into a DWG file.
8 REPLIES 8
Message 1 of 9
C3D_User
4103 Views, 8 Replies
Good morning all....
I am xrefing a DGN file into my DWG file in Civil 3d 2012.  When I go into Layer Manager I cannot see any of the DGN's Levele/Layers?  Tell me this isn't so? Am I missing something here, how is one suppose to control Layers in the DGN when it is XREF'd into a DWG?
Thanks in advance,
K
Spoiler
8 REPLIES 8
Message 2 of 9
LARRYGILL
in reply to: C3D_User
It is possible your DGN is empty, except for internal reference files contained in the DGN file.
Open the DGN file and examine the reference files.
You may need to create a separate DGN file that makes all of the references "ACTIVE", same as "BIND" in autocad.
Message 3 of 9
jmayo-EE
You may also have a layer filter appplied which hides xref layers.
John Mayo
Message 4 of 9
Neilw_05
in reply to: jmayo-EE
I haven't used DGN's as references to any extent but one thing to be aware of is that DGN's can have multiple model spaces, so when you attach a DGN you need to specify which model within the DGN you want to attach. You may have chosen a model with nothing in it.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 5 of 9
Hidden_Brain
I believe commandline>ULAYERS brings up the dgn layers (levels).
Message 6 of 9
jim.poole
in reply to: LARRYGILL
Can one examine a .dgn file without Microstation?
I have received 4 No large .dgn files (200-400MB).
I'm using Civil 3D 2018 which refuses to DGNIMPORT any of them, I can XRef them all in but see nothing.
ULAYERS brings up the .dgn layers but alas I can't see anything, even zooming right in, right out - nadda... confusing.
Would a 2020 .dgn display - is there dodgy backward compatibility between the 2 systems?
Message 7 of 9
pendean
in reply to: jim.poole
You are replying to a year 2012 thread.
See your other post https://forums.autodesk.com/t5/civil-3d-forum/importing-dgn-files/m-p/9608044#M429641
Message 8 of 9
ChicagoLooper
Could be bad export from MicroStation.
Test using another program like Google Earth Pro=>File=>Import=>Change files of type to MicroStation=>Browse to and select your MicroStation dgn=>In the GE Pro pup a check in the dgn box  in the Places Panel on the left.
Chicagolooper
Message 9 of 9
Neilw_05
in reply to: pendean
Hate when that happens
WIN 10 64 PRO
Rail Community
