Civil 3D Forum
XML Surface will not display object contours after import
1 REPLY 1
civman_daar
562 Views, 1 Reply
C3D 2012 SP4
Win7 Pro
I have a surface that was originally 3D polylines with elevation.  I exported it to XML.  I imported the XML file into another drawing. The surface appears in the prospector, but the surface style contours, triangles, points do not appear.  If you hover over the surface area, a Z elevation is returned by the cursor. I data short cutted the surface into another drawing and it appears fine in that drawing.  Why wont the XML surface display in the import drawing?  My contour intervals are correct; 1' and 5' and the objects are on in the surface style.
1 REPLY 1
Try turning off level of detail. I find that particular function buggy and interferes with contour display.
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Rail Community
