apweng wrote:
> What is the easiest way to save information in the settings tab of
> the XML report generator. Say for example we have multiple clients.
Andrew,
One option is to have multiple copies of the settings file (which itself
is an XML file) and rename the one with the appropriate client info to
the one that the Report Generator expects when you generate reports.
The settings file is:
%USERPROFILE%\Local Settings\Application Data\Autodesk\LandXML Reporting
6\Support\RepGenSettings.xml
Create a copy for each client, like RepGenSettings_ClientA.xml, etc. and
rename to RepGenSettings.xml using a script or a batch file, or manually
as you need to use it.
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
