Civil 3D Forum
XML Reporting
3 REPLIES 3
apweng
189 Views, 3 Replies
XML Reporting
What is the easiest way to save information in the settings tab of the XML report generator. Say for example we have multiple clients.
Andrew
3 REPLIES 3
in reply to: apweng
Andrew,
One option is to have multiple copies of the settings file (which itself
is an XML file) and rename the one with the appropriate client info to
the one that the Report Generator expects when you generate reports.
The settings file is:
%USERPROFILE%\Local Settings\Application Data\Autodesk\LandXML Reporting
6\Support\RepGenSettings.xml
Create a copy for each client, like RepGenSettings_ClientA.xml, etc. and
rename to RepGenSettings.xml using a script or a batch file, or manually
as you need to use it.
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
apweng
in reply to: apweng
Thanks Himanshu,
That helps for now. It would be better if we could save the customer profile from within the XML report generator.
Andrew
in reply to: apweng
A wish-list item has been filed for this. Thanks for bringing the issue
to our attention.
Rail Community
