Never ran into this problem. Did an eTransmit and sent a file to someone and they responded can't load xml file. Gives an Error "Created by newer version".
I saved the drawing down to an earlier version before etransmit. This drawing doesn't have any 3D elements. Anyone ever ran into this error before?
thanks
Solved by drafter1411. Go to Solution.
Are you sure Civil 3D is not trying to bundle referenced data shortcut items like surfaces or alignments or maybe you have a surface that was imported from an xml file?
Did you use a simple Saveas to save back to the old version. If so, consider using ExportToAutoCAD2010 (or 2000, 2004, 2007.)
Best regards,
Tim
Thanks for your reply, The guy I sent the drawing to was trying to load a surface from another drawing. Why he was doing this I do not know, but that was the problem.
