Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
Did you mean:Ā
xml file error
3 REPLIES 3
jmatte2004
1337 Views, 3 Replies
xml file error
when in part building i edit a part and want to save it as a different name i get a error saving xml file and it does not save the new part. any idea.
thanks
jason m.
3 REPLIES 3
NatyRofner
in reply to: jmatte2004
Hello Jason,
Typically this is caused by a permissions issue on your machine. First we would suggest selecting the Civil 3D desktop icon, right click, and select properties. In the dialog select the COMPATIBILITY tab and check the RUN PROGRAM AS AN ADMINISTRATOR under the Privilege Level heading. After doing this, test saving a new part and see if it helps. Also, please ensure you have full permissions to this folder and see if that helps: C:\ProgramData\Autodesk\C3D2012\enu\Pipes Catalog.
Please, let me know if this solution solves your problem.
Best Regards,
Naty
Natanielly Rofner
Product Support Specialist
Autodesk Global Subscription and Support
jmatte2004
in reply to: NatyRofner
thanks that was the solution to the issue
amrfooda2008
that was so useful thanks
Rail Community
Ā
Ā
