Civil 3D Forum
X section explode question.
1 REPLY 1
411 Views, 1 Reply
Hi I am very inexperienced with Civil 3d. Our office just upgraded from civil 3d 2005 to civil 3d 2012 and frankly I'm blowing in the wind here! I have finally stumbled my way to cutting cross sections on a turn lane. I would like to explode the turn lane x sections and do some editing and labeling manually. If I explode the sections they disappear. In an older post someone mentioned selecting and exploding the section prior to exploding the section view. Not exactly sure how to go about this.
Could someone explain the steps needed to explode these sections? Thank you in advance!  Tom
1 REPLY 1
andrewpuller3811
To get you started, if you select all the part in the section view, use a windows around all the entities in the section views, and then explode it. If you select the section view by clicking on it, the section will disappear as you have found.
Sections are on visible within section veiws. If you remove a section view from the drawing, the section has nothing to be displayed in. Just as section labels are dependant on section, remove the section and the label disappears.
You might want to look into some of the tutorials and webcasts, as just about any labeling and editing is possible with the section views intact, using the right styles and assemblies.
Try here for starters
http://usa.autodesk.com/adsk/servlet/linkedsumindex?siteID=123112&id=2387188&linkID=9240695
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Rail Community
