How do I get the cross sections to display a cut/fill value?
Solved by tcorey. Go to Solution.
First you have to Compute Materials.
After the Section Views have been added to the drawing, select one of the Section View objects. On the Ribbon find and run View Group Properties.
In the dialog, find the Section Views tab. Find the column named Change Volume Tables. It might only say Change Vol... because the column is too narrow. Click the ellipsis button and specify the volume table style you want to use.
