Civil 3D Forum
wrong Corridor Surface
4 REPLIES 4
happyboy395
556 Views, 4 Replies
I create a corridor by subassembly with 2 LinkOffsetOnSurface and 1 LinkMulti
but corridor surface (red line) did not match to it
4 REPLIES 4
Jay_B
in reply to: happyboy395
When creating Surface on surfaces tab in corridor properties was "Top Links" specified for overhang correction?
Does the Code Set used contain the codes Top and Datum?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
happyboy395
in reply to: Jay_B
i used Code contain the codes Top and Datum
sboon
When you add the links to your surface definition make sure that the Add as Breakline box is checked.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
BrianHailey
Only use one of the codes, top or datum. No need to add them both. Additionally, as previously mentioned, make sure you add an overhang correction to your corridor surface (in most cases it doesn't matter if you do top or bottom links).
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Rail Community
