I have a workspace set and it will function fine for a couple of weeks, and each time I start my machine or Civil 3D, everything will be proper. But every couple of weeks it will reset, the name of the workspace will still be there, and it will let me load it, but the settings, toolspace and other menus will not be in the correct spot.
After this happened a couple of times, I then began saving my workspace twice, one named backup and the other named "Larry Civil 3D". I would only use the Larry Civil 3D, but again, after a period of time it would reset and both the Larry Civil 3D and the Backup would not work.
Any thoughts on this issue?
Thank you,
Larry
Since this issue is not related with Civil 3D API directly, I've asked administrator to move it into Civil 3D general borad, where you can get more exposure to Civil 3D product experts.
In your Workspace Settings, is it set to Automatically Save Workspace Changes? By default, it's set to Do Not Save Changes to Workspace.
It is not set to automatically save my settings. The problem is that after an undetermined amount of time, it forgets the workspace settings.
The process I have repeated a number of times in the past year:
After some weeks, when I open Civil 3D, both the Larry's Workspace and Backup workspace, while still there, do not reflect the settings I initially made.
