New Member
asadrizwan
Message 1 of 5 (130 Views)
Working with FBK and NAD 83
130 Views, 4 Replies
11-22-2013 09:14 AM
I have three FBK files (also have the dwg)
Does anyone know how to merge the NAD 83 with base DWG?
Please help
Active Contributor
wetsnow13
Message 2 of 5 (126 Views)
Re: Working with FBK and NAD 83
11-22-2013 09:40 AM in reply to: asadrizwan
Your FBK's are in NAD 83? Your dwg is assumed positions?  Your post is a little lacking.
Import your survey data in your prefered manner and use coincident points to translate and rotate the linework from the drawing to the NAD 83 point data.
New Member
asadrizwan
Message 3 of 5 (118 Views)
11-22-2013 09:57 AM in reply to: wetsnow13
Basically i have topographic information in about three FBK files along with a dwg file. The FBK file is in NAD83 but not merged with base dwgs.
How can i merge them together?
I am interested in finding out the grade elevation..
Active Contributor
wetsnow13
Message 4 of 5 (108 Views)
11-22-2013 10:17 AM in reply to: asadrizwan
is the base drawing in NAD 83?  You can import the the FBK's using the Survey tab of the toolspace or by clicking "Import Survey Data" on the home ribbon.  You probably want to read the help manual for survey data if you have never done this before.
Valued Contributor
g_k50
Message 5 of 5 (87 Views)
11-22-2013 02:12 PM in reply to: asadrizwan
Set the drawing to NAD83 using the Drawing Settings
