Member
arick4022
Message 1 of 10 (585 Views)
Working back and forth from plan view and profile view
585 Views, 9 Replies
01-18-2013 10:36 AM
I was given a horizontal centerline of a 5 mile bike path. We have to stake all the even stationing every 50 feet and all the VPC's and VPT's with vertical elevation. I have created the horizontal profile and also the vertical profile including all the vertical curve information. Is there an easy way to incorporate the elevation information back into the plan view so I can create points that carry x,y & z points that I can transfer out of autocad as a .txt file so we can upload it on our gps equipment?
Thank you for all of your help!!
Aaron M. Rick, PEI, LSIT
EDR ENGINEERING
4900 Waters Edge Drive, Suite 170
Raleigh, North Carolina 27606
troma
Message 2 of 10 (573 Views)
Re: Working back and forth from plan view and profile view
01-18-2013 11:31 AM in reply to: arick4022
Would a corridor help?
I've seen others talking about exporting a profile as a feature line in plan view, but I can't find how to do it.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Jeff_M
Message 3 of 10 (550 Views)
01-18-2013 12:29 PM in reply to: arick4022
Create Points->Alignments, Measure and then Profile Geometry Points That will likely give you more than you want, but the points won't be in order since it's a 2 step process.
sboon
Message 4 of 10 (546 Views)
01-18-2013 12:35 PM in reply to: arick4022
Forget about exporting points, that's the old school way of doing layout.  Your GPS equipment can probably accept the alignment and profile directly, so that you can layout the path at any station and offset you want.
What type of equipment are you using in the field?
Member
arick4022
Message 5 of 10 (533 Views)
01-18-2013 12:59 PM in reply to: sboon
We have a Leica TCRP 1203 Robotic Total Station. How do you transfer the alignment and profile information from AutoCAD Civil 3d 2010 to the Leica?
sboon
Message 6 of 10 (493 Views)
01-19-2013 10:22 AM in reply to: arick4022
Try this link.
Most survey equipment can also use xml files exported from Civil3d.
Joe-Bouza
Message 7 of 10 (482 Views)
01-19-2013 07:01 PM in reply to: troma
Hi troma,
There are a few options:
you can create label style that show the vertical profile with the station labels
you can create points by station offset (i think that can also be done by reading a txt file - I remember doing it in LDT so c3d must have it)
you can create a fl from the alignment
Allen and John have talked about turning on the 3d chain in the style , exploding the profile and being left with the profile in plan
Almost forgot there is the tool box reports too
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
AllenJessup
Message 8 of 10 (455 Views)
01-20-2013 06:22 AM in reply to: arick4022
if you explodethe chain remember to do it to a COPY
Because it explodes the whole profile.
troma
Message 9 of 10 (418 Views)
01-21-2013 10:07 AM in reply to: Joe-Bouza
Joe-Bouza wrote:
Hi troma,
Where is this command?  I can't find it.  What does it do if you have multiple profiles on that alignment?
I don't know what that means.  What & where is 3D chain?  Not supprisingly it doesn't show up in the help.
Almost forgot there is the tool box reports too.
Are these for creating a feature line or points or just an xml report?
Joe-Bouza
Message 10 of 10 (408 Views)
01-21-2013 11:00 AM in reply to: troma
troma wrote:
Joe-Bouza wrote:
Hi troma,
The fl can be dynamic to the profile changes if the check box is selected. One caviat: thelayout must match existing at both ends or you can get unpredictable results
REPORT
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
