I'd like to design a few different options for an earthen berm in the same spot. How do I keep them all separate? For instance, I'd like to have a hill at different heights along with different side slopes. I thought I'd just use different surfaces, but even when I turn the surfaces to no disaplay, I still have my feature lines staying put.
My goal is to build sheets showing each hill option with an earthwork computation for each option. I'm sure this is a simple endeavor, I'm just looking for a way to keep it clean.
I'd like to do each option in its separate site, and then just be looking at one site at a time. Is this possible?
How about Data Referencing the design surfaces into seperate drawings/sheets for plan production?
HTH
AWood
It's actually a pretty simple process, similiar in idea to external references (XREFs).
There are in-software tutorials to guide you through the process.
http://docs.autodesk.com/CIV3D/2012/ENU/filesCTU/GUID-68AC7599-F635-4391-9F9A-6E9EF96F9ED-102.htm
HTH
AWood
neilyj (No connection with Autodesk other than using the products in the real world)
all good suggestions. This was a question only a few days ago you may find interesting >>>HERE<<<
