Anyone have any ideas why my WMS photography is not rendering when i plot to PDF.. It looks find on screen in paperspace... But when i go to plot it doesn't render correctly... See below...
In paperspace.. looks fine
PDF plot... aerial photo not rendered!! ahhh
SOLUTION FOUND
if you have a WMS connection and it is not rendering when you plot. Then it is your "print quality" settings that need to be changed.. If you have them set to custom they will not work.. Set them to Normal or any other one and problem solved..See below.
Regards
Kapanther
Hi there. Do you have any idea how to control the lineweight of a WMS-object? In the Civil 3D view on the right the red lines and the red text has a sufficient lineweight. When I plot it as PDF or whatever, the lines and the text becomes superthin (left side of picture). As far as I can see adjusting lineweight in the plot setup does not have any impact on the WMS-objects.
