Civil 3D Forum
WMS image transparency in C3D 2012
8 REPLIES 8
Message 1 of 9
karlkarpuk
2465 Views, 8 Replies
Hey!
I have a problem finding a solution to how to adjust the transparency of my WMS image.
Does anyone know if it's even possible?
I'm using Civil 3D 2012.
8 REPLIES 8
Message 2 of 9
antoniovinci
in reply to: karlkarpuk
Best practice would be to save locally the WMS image as Geotiff file (in Qgis) then handle trasparency either as monochromatic image (in Autocad) or as .PNG one (in Irfanview) or adding an alpha channel (in Gimp).
Message 3 of 9
karlkarpuk
in reply to: antoniovinci
Does the fact that i didnt understand almost anything, make things more complicated?
Isn't there a built-in function for that?
Message 4 of 9
antoniovinci
Message 5 of 9
Murph_Map
When you connect to the WMS files there is the transparency control in the data connection palette. Depending on the server and images as if you can control it.
Murph
Supporting the troops daily.
Message 6 of 9
karlkarpuk
in reply to: Murph_Map
I am unable to find that option in the data connection pallette. There is one to control the transparency of the pallette, but not the WMS image.
Message 7 of 9
karlkarpuk
Ok so i found a solution to my problem.
At first, i had to save my raster layer as a .layer file.
Then i had to open it using notepad.
Then, betwee the lines <FeatureName>WMSLayers:MA-FOTOKAART</FeatureName> and
                                      <Geometry>Image</Geometry>
     i had to type <Opacity>0.5</Opacity>  where you can change the number accordingly to your eneds.
Eventually the notepad file looked like the one i attached as "opacity.jpg"
Now i had to save the file and do Task Pane -> Data -> Load Layer where i chose the now modified layer.
The end product looked like the one on the second attachment.
The point of all this was that i wanted the map image under my project plan so the plan would be easier to understand, but i didnt want the map to disturb the drawing itself if you know what i mean.
Message 8 of 9
karlkarpuk
Wierd. The transparency only seems to show out when in 2dwireframe. In all other shademodes the image is not transparent at all. 😞
Any clues why is that so?
Message 9 of 9
igi_pop
Brilliant! Thanks man!
I know it's an old topic, but i'm publishing something with maps underneath (25k's, pastel colours) i REALLY wanted to dim them. Had i used MAP more in the past, maybe it would occur to me as well. I learned something new today, two things actualy 😄
Cheers,
Igor
Lenovo ThinkCenter M920f; Win10pro x64; i5 9500 @3GHz; 16GB RAM; Radeon RX550X
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
Rail Community
