I am running C3D 2013.
Is it a good practice to have several WMS connections already connected to the provider in our standard "dwt" template file? Will this affect the speed or performance of a drawing?
Any reply/information is appreciated.
Thanks.
Solved by machadt. Go to Solution.
Hi Jim,
I would say that is a personal preference, yes it is possible, if it is or not a good practice that is up to you.
Every user is unique on their own environment, what it work for you it may not work for somebody else.
I think that you should try it because this is not a common practice.
Then you could let us know the results.
Hope this help!
