I would like to propose that Profile and Section styles should be set in the Surface object properties.
Rarely would you need the same surface shown differently in different profiles or cross-sections and an override could satisfy what I believe to be the small minority who would need that functionality.
From a production standpoint it's better if the styles for profiles and sections are tied to the surface object and can be manipulated at the main object. If I'm cutting a dozen or more profiles for sections I don't want to have to remember and keep consistent the same styles for the same surfaces. Profiles and Sections are dependent children of surfaces.
I have mocked up how i think this could be delivered in the surface style dialog box.
Cheers
Paul
@theminiguy wrote:I would like to propose that Profile and Section styles should be set in the Surface object properties.
Cheers
Paul
How would you handle user created profiles since they aren't tied to a surface?
Do you mean "Quick Profiles"? If yes, then I would suggest that it extacts what ever the profile settings are to create the static profile.
If not, can you please explain further what you are refering to, when you say "user created profiles"...
Cheers
Paul
Cheers
Paul
My first thought is Design Profiles. These have no surface associated to them.
Ahh..
Ok, Currently in the setting for creating a user defined profile I have an "Editing" style, to allow me to manage my corridor designs. From my corridor designs i create my surfaces, and then create production drawings down stream that i data shortcut my surfaces into.
Cheers
Paul
@theminiguy wrote:Ahh..
Cheers
Paul
So a designed profile is tied to the corridor? I'm confused as a style is just how an object looks. If profiles are tied to surfaces, then I still don't see how a design (user created) profile would work. You can't create a corridor without a profile, so if you're using your corridor surface to get a profile then you have a chicken before the egg problem.
Also, just to extend on the thought, referencing the resultant corridor surface to show your profile would not be the same as the design profile. The corridor, by function, may or may not break at a design profile PVI (this is controlled with the corridor settings) and will not show a true vertical curve, since the corridor approximates the vertical curve based on the sampling intervals and will tesselate at all horizontal and vertical curves. This will make labeling vertical curves in the profile view extremely difficult if based on the corridor surface.
I see what you saying. I agree if you only want the IP, curve and straight lengths/grades shown you need to use the design profile in production.
I am not proposing to remove Profile/Section Styles; but make the use of any profile cut of a surface to be managed at a parent level - the surface style which is just setting (or not if you dont want it) what the child Profile/Section style is...
Cheers
Paul
