I have a drainage structure table for a leaching system. I used some expressions to calculate some of the leaching pool values for the Top Of Rings etc. When the expression is false I get a zero. The expression work as expected, and I anticipated manually wiping out the false value, but when I wipeout or solid mask the values in MS they don't line up in the view port. Does anyone know how to effectively wipeout structure table cells?
Joe Bouza
Solved by Hidden_Brain. Go to Solution.
Mark Green
Working on Civil 3D in Canada
Joe Bouza
Mark Green
Joe Bouza
when you were placing the wipeouts in MS, was your MS scale the same as your sheet viewport scale where the table is printing?
Joe Bouza
