Civil 3D Forum
Wipeout
9 REPLIES 9
Message 1 of 10
david1960
381 Views, 9 Replies
Wipeout
I have been using the wipeout command and freezing the frame. When I do a plot preview it looks okay. But when I go to plot the wipeout area grayed. How do I turn off this graying of the wipeout area?
9 REPLIES 9
Message 2 of 10
civman_daar
in reply to: david1960
Instead of freezing the layer, turn " tframes " off.
Message 3 of 10
david1960
That is what I meant to say I turned of the frame. Is there a setting under options would cause the wideout area to be grayed?
Message 4 of 10
Sinc
Are you printing directly to a printer?
The only issue like that I've seen involves using a DWF underlay. The DWF underlays have settings for "Contrast" and "Fade", and by default, these are set to Contrast=75 and Fade=25. One or both of these settings causes wipeouts to print grey - I think it's the Contrast setting. By changing the Contrast to 100, wipeouts will mask completely again.
That's the only time I've ever seen wipeouts print grey.
-- Sinc
http://www.ejsurveying.com
http://www.quux.biz
http://www.sincpac3d.com
Sincpac-C3D v2.1 now available!
Sinc
Message 5 of 10
david1960
No we are not sending directly to a plotter we are making plot files and sending then out to be plotted. Like you I have never seen this.
Message 6 of 10
AllenJessup
I can't say why this is happening. It may be a problem with the plotter driver. See if there is an update.
A a workaround I would suggest setting a color or plot style to a 0% shading and assigning that color or plot style to the wipeout frames.
Allen
Allen Jessup
CAD Manager - Designer
Message 7 of 10
AllenJessup
Allen
Allen Jessup
Message 8 of 10
cstringer80
Are you using Adobe and making PDFs? I've noticed Adobe and some other PDF type writers can't handle CAD and Wipeouts. We fixed the problem by purchasing BlueBeam PDF writer. I think you can download a free trial to get stuff out the door right away.
Message 9 of 10
david1960
We are creating PLT files but I will try BlueBeam, Thanks
David
Message 10 of 10
Sinc
You could also try the route Autodesk wants us to use, and try sending out DWF files to be printed. Or you might get a "What's a DWF?" response from your printing company. But it might work.
-- Sinc
http://www.quux.biz
Sinc
Rail Community
