Scott McEachron wrote:
> Actually, Aero should have little impact. In a nut shell, Aero utilizes the
> GPU, not the CPU, and runs in a different space - it *shouldn't* have an
> impact on Civil 3D.
> Whereas I would recommend running Civil 3D on XP using the "Classic Windows"
> theme, this isn't, or shouldn't be, necessary with Vista. Maybe your
> problem isn't C3D related at all, maybe it's your choice in graphics card -
> just a thought. I'm running an nVidia card with 512 Mb on board.
The speed of your computer is not just CPU, but the entire system. I did
not have a choice on the video card - its a portable (ThinkPad G42). My
Vista experience rating is 3.8, which should be adequate. According to
the second article on the link that you provided, disabling Aero DID
speed things up for that user, as it did for me. This is logical,
because, if you reduce the computing resources needed to maintain the
GUI, those resources are available for other applications, such as
AutoCAD, which needs quite a bit of graphics resources all by itself.
