Chris... Basically, that is the error I was receiving. The save command
wouldn't give me that message even until I hit the escape key. As far as I
can tell, I did not have any commands running. I have 5 surfaces in this
drawing and it was the only drawing open.
Drawing activity to this point:
1. Import surface from Land Desktop project.
2. Computed 3 set of volumes (4 surfaces involved, 4 of them compared to a
"base" surface)
After the 3rd set of volume calculations is when the problem occurred and
the symptoms of the first e-mail were noticed.
Propspecor Open. Volume workspace open. Drawing units are in meters.
If you would like me to upload the drawing to customer files I can.
"Chris Putnam" wrote in message
news:ABA92ED284AC14904151EBFF82D3CBF2@in.WebX.maYIadrTaRb...
> Ron,
> The closest message I could find was:
> Document "" has a command in progress. Retry/:
> Is that the one you were getting? While a command is in progress, the
> drawing is "locked" so that modeless tools (such as our toolspace) can't
> interfere with what the command is doing. Likewise, toolspace needs to
lock
> the drawing before it can do anything (so that a command can't interfere
> with it), and unlock it when finished.
> 1) Were you working on more than one drawing, or just one?
> 2) You were working on volumes when this happened -- do you have any
> more specifics about what you were doing (commands, prospector menus,
etc?).
> In order to fix this, we need to be able to repeat the problem, so we'd
> appreciate as many details as you can remember.
> 3) Were you able to type either of the keywords (retry/cancel), or was
> keyboard input broken too?
> Chris Putnam
> Software Engineer
> Autodesk Civil 3D Team
