Member
0 Kudos
Post 1 of 4
Widenig Curves
304 Views, 3 Replies
05-04-2012 08:49 AM
Hi All,
Im using Civil 3d 2012 and I couldnt find the function that I could offset the smooth curve aligment as shown on the attached pdf. I've looked thru the offset alignments but those linear, curve-cuve-reverse curve, curve-line curve doesn't help much. I would appreciate it if anyone might know the solution.
Regards
161 Kudos
Post 2 of 4
Re: Widenig Curves
05-05-2012 05:16 AM in reply to: wilwil02
You will probably need a spiral.  It appears you probably have a "varying" radius.
Bill
267 Kudos
Post 3 of 4
Re: Widenig Curves
05-05-2012 07:46 PM in reply to: wilwil02
When applying a widening through a curve it does not create a smooth transition. It segments it along the curve (I believe in 3 segments).
After a bit of testing, I've confirmed this:
The green line is the alignment and the white line is the offset alignment that transitions it's width from start to end of curve.
Brian Hailey
CAD-1.com
My Blog
Distinguished Contributor
4 Kudos
Post 4 of 4
Re: Widenig Curves
10-26-2012 08:25 AM in reply to: BrianHailey
Has anyone figured out a way to dynamically increase the smoothness of the transition? Or an I stuck doing the transition manually to get it to look right? Seems like there should be a setting somewhere for this.
Civil 3D 2015
Windows 7 Pro (64bit)
Intel Xeon W5580 @3.20GHz
12gig RAM
NVIDIA Quadro 600
