Civil 3D Forum
Why doesn´t exist automatic regeneration superelevations?
3 REPLIES 3
joantopo
297 Views, 3 Replies
If I have calculated the superelevations and then edit the alignment (for example,I  modify the length of spiral), the superelevations doesn´t recalculate. Why?
The guitar (superelevations) in profile view is old. If I load again the style profile view, the data are the same about superelevations.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
3 REPLIES 3
joantopo
in reply to: joantopo
Other problem is that I show the superelevation labels in the superelevation guitar(profile view).
In the first superelevation calculate it´s right but if I delete the data superelevation and re-calculate again, the labels about data superelevation show this: ???
sboon
Minor issue first - this is a guitar.  I believe that you're talking about a superelevation band.
Exactly what type of labels are you displaying?  I've been trying to recreate the error you reported but every time I recreate the superelevation all of the labels appear normally.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
joantopo
Solved.
I was using the labels "Inside lane" instead of "outside lane" for only One lane.
Rail Community
