If I have calculated the superelevations and then edit the alignment (for example,I modify the length of spiral), the superelevations doesn´t recalculate. Why?
The guitar (superelevations) in profile view is old. If I load again the style profile view, the data are the same about superelevations.
Other problem is that I show the superelevation labels in the superelevation guitar(profile view).
In the first superelevation calculate it´s right but if I delete the data superelevation and re-calculate again, the labels about data superelevation show this: ???
Minor issue first - this is a guitar. I believe that you're talking about a superelevation band.
Exactly what type of labels are you displaying? I've been trying to recreate the error you reported but every time I recreate the superelevation all of the labels appear normally.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Solved.
I was using the labels "Inside lane" instead of "outside lane" for only One lane.
