Distinguished Contributor
cadman33619
Message 1 of 21 (461 Views)
Why does my linetype change if i rotate passed 180 degrees?
461 Views, 20 Replies
11-01-2012 09:53 AM
i have a simple fence line type with "x"s....if i draw the line straight up or to the right it looks perfect. but if i draw it anywhere to the left then the Xs are off centered. How can i correct this?
thanks
Have you tried the linetypes that ship with Civil 3D? There are two barbed wire fences in the AeccLand.lin linetype file that contain an "X" that stay centered in the line as the line is rotated.
Peter Funk
BrianHailey
Message 2 of 21 (456 Views)
Re: Why does my linetype change if i rotate passed 180 degrees?
11-01-2012 10:11 AM in reply to: cadman33619
Look in your linetype definition and see if it has a "u=0.0" value in it. THIS post explains what I'm talking about.
Brian Hailey
CAD-1.com
My Blog
cadman33619
Message 3 of 21 (451 Views)
11-01-2012 10:26 AM in reply to: BrianHailey
i know what you mean...i do have U=0.0 but thats not really the issue i'm having. here is an example...
the top one i drew from left to right.
the next one i drew from right to left,
the next from top to bottom
the next from bottom to top.
if i rotate that last one so that its pointing north east then it will look perfect.
here is my .lin file:
*FENCELINE,X
A,.5,-.2,["X",STANDARD,S=.05,U=0.0,X=-0.13,Y=-0.025],.05
AllenJessup
Message 4 of 21 (446 Views)
11-01-2012 10:55 AM in reply to: cadman33619
I, personally, don't like using text X's for fence lines. I long ago created a shape to use instead.
*FENCEX,Fence with Xs
A,1.0,-0.09848,[FENCEX,FenceX,s=.05],-0.09848,1.0
Allen
Rename FenceX.txt to FenceX.shp if you want the shape file.
cadman33619
Message 5 of 21 (431 Views)
11-01-2012 11:50 AM in reply to: AllenJessup
thanks....can you tell me how to add that new line type to acad? it doesnt seem to work the same as adding a .lin file.
(acad 2011)
AllenJessup
Message 6 of 21 (426 Views)
11-01-2012 11:55 AM in reply to: cadman33619
Not sure what trouble you're having. You can either add that definition to your .lin file or put it in it's own FenceX.lin file and load it from there. The FenceX.shp file has to be somewhere in your search path. I tested it in 2012 and it worked there.
Allen
cadman33619
Message 7 of 21 (423 Views)
11-01-2012 11:57 AM in reply to: AllenJessup
ok i understand now. i added it to the support folder and i was able to load it. but i'm still not sure how to use it.
AllenJessup
Message 8 of 21 (413 Views)
11-01-2012 12:17 PM in reply to: cadman33619
OK.
Should be in either your Acad.lin, AeccLand.lin, your company standard .LIN file or a .LIN file by itself. The FenceX.txt file should be renamed FenceX.shx and put in your search path.
You should use the Linetype command and select Load from the upper right hand corner of the Linetype Manger dialog box. In the Load or Reload Linetypes dialog box select File in the upper left just to the right of the current .LIN file name. Unless that current name is where the new definition is. After the correct file has been selected, scroll through the selections in the lower pane of the Load or Reload Linetypes dialog box and select FENCEX, Then OK out of that dialog box. Now scroll through the selections in the lower pane of the Linetype Manger dialog box. FENCEX should show as a currently loaded linetype.
Now just use that as you would any other defined linetype.
Allen
cadman33619
Message 9 of 21 (404 Views)
11-01-2012 12:27 PM in reply to: AllenJessup
what i'm confused about is the .lin and the FenceX.txt.....
i open text editor and paste:
and save it as fencex.lin, correct? so where does the FenceX.txt come from?
AllenJessup
Message 10 of 21 (401 Views)
11-01-2012 12:33 PM in reply to: cadman33619
Attached to my original post is a file FencX.txt. The discussion group wont let me post a .SHX file so I renamed it to .TXT so I could post it.
Allen
