I installed 2014 C3D and tried an imx export. It simply uses the drawing name for the imx, and makes it even if a file by that name exists.
the help says it asks for a name, what is up?
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Solved by machadt. Go to Solution.
It sucks, but the Help is wrong. Wishlist it.
Do we need an UN-wishlist for things they took away?
I'm kidding, they cannot possibly have done it on purpose....
That is what I wondered. If you try to export the imx it justs exports the imx with the name of the file you want to export in the same path as the file. It is not such a big issue since the only time you would have the issue would be on overwrite. But you are right, either it is a bug or they changed stuff to act that way and did not update the help properly.
So no one at AutoDesk tried making an imx with 2014?
I know they did, just wondering how that slipped.
