i have daylight_cut at say station 100, then sampled every 20m, however it connect from station 100 all the way to 1000 for example. because there is no such code in between. why can't it create seperate featureslines? the thing is sometimes it does it and sometimes it doesn't.
see the redline cutting across the corridor? shouldn't be there.
i asked this before but no one knows. maybe corridor too big it does that? it's 60k km.
I'll bet that you have SP2.1 installed. See this thread.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Civil-3D-Service-Pack-2-1-HEADS-UP/td-p/3603270
looks like this is it.
so only way is to reinstall the whole thing? this is not good news. i don't think i put in the service pack. it came with it when i got the computer from IT.
Check the info in the top left corner of the About Civil 3D dialog to find out which SP you're currently using. The reinstall is only an hour or so, it won't ruin your whole day.
it's a display thing. if you click on it when extracting? doesn't do anything. still annoying problem if you are gonna export to cad after then have to delete those one by one. extra work.
the sp2.1 has they fixed these problems and updated their one or not?
maybe copy and paste the arx files from old computer can fix it? easier lol.
